Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Pump runs but does not filter - Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
  • Intex Master
  • 8,404 Answers
What is the filter media and is it intact and in place???
Posted on Aug 06, 2010
Hi there I have a spaform oslo.The problem I got is that the filtration sequence is running all the time the jets are constantly on speed 1. The Tub is up to temp I have no fault codes. Thanks Justin
make sure correct time is set on unit, then double check to see if filter cycles were ever change, follow manul instructions attached.
Filter Cycles
On all systems, the pump and the ozone generator will run during
filtration. At the start of each filter cycle, the blower [if
fitted] will run for 30 seconds to
clean out the air channels. Pump 2 and pump 3 [if fitted] will run for 5 minutes.
There are two filter cycles per day. The start/finish times of
each cycle are programmable. To program, follow the steps under
the heading
How to set the
time & filter cycles
on page 9, ensuring that you press
"Mode/Prog" to advance to the next setting option.
The factory default filter cycles are as follows:
The first filter cycle is automatically activated at
8:00AM and operates the pump until 10:00AM. The '
F1'
indicator icon on the control touchpad will be lit
when filter cycle 1 is running.
The second filter cycle is automatically activated at 8:00 PM
(20:00) and operates the pump until 10:00 PM (22:00). The
'F2'
indicator icon will light when
filter cycle 2 is running.
http://thecoverguy.co.uk/wp-content/uploads/2015/05/Spaform_Owners_Manual.pdf
Jan 07, 2016 | Pool & Spa
Where is the fuel sensor on a 1997 jeep grand cherokee
Have you checked the fuel filter? I would pull the fuel line apart before the filter to see if the pump is putting gas into the line. With key on, the pump should run for 2 seconds to pressurize the lines and fuel rail. And when the engine is cranking over, the pump should be running constant and putting gas into the line. If gas shoots out, possibly the filter is clogged or the fuel pressure regulator on the fuel rail is defective. If no gas comes out, possibly the pump filter sock is clogged or the pump is defective.
Very unusual for the pump to run and have NO fuel pressure.
Aug 07, 2014 | 1997 Jeep Grand Cherokee
How do you backflow a pool pump?
I assume you mean backwash the filter. The pump will always pump in one direction.
I am also assuming that you have a sand filter with a filter control valve.
If your filter's waste discharge needs a hose attached to route the discharge to a ditch or other suitable location, be sure to attach the hose before beginning this process.
Turn the pump off. Set the filter control valve to the backwash position. Turn the pump on and run for 30 sec to 1 minute until the water being discharged looks clear. If your filter control valve has a Rinse setting, turn the pump off, set it to Rinse and run the pump for about 30 sec. Turn the pump off. Set the Set the filter control valve back to Filter and turn the pump back on.
Jul 23, 2014 | Pool & Spa
How to use back wash
backwash is easy. dont let it scare you.
here are the steps:
-turn off pump
-roll out backwash hose
-push down on handle and rotate to backwash
-turn pump back on
-depending on type of filter, run for minimum 2 minutes (watch discharge water. run until it is clear) if there is a glass vial, you can watch that until water is clear.
-turn off pump
-push down on handle and rotate to rinse
-turn on pump and run for 30 seconds (water will leave discharge hose)
-turn off pump
-push down handle and rotate to filter
-you can run pump immediately
May 20, 2014 | Hayward SAND FILTER, PRO SERIES
How to change 1984 chrysler new yorker 2.6l from an electric fuel pump to a mechanical fuel pump.
Replace the mechanical pump with a new unit and that will remove any reason of broken/failure from the equation. Remove the electric pump altogether and leave 1 filter in the line before the mechanical pump. Mechanical pumps are not in favour with some people who have no idea that they can be adjusted to give more pressure and greater volume for the bigger capacity engines. Some mechanical pumps are more expensive to repair / replace but if you price an electric pump to supply the volume that a properly adjusted or a larger capacity mechanical pump then the cost saving is minimal. Unless you get a fuel filter that is rated with a smaller micron rating than the standard filter any number of filters will not work as the smallest particle will get through the lot
Nov 21, 2013 | Cars & Trucks
How do you backwash your pool
if you have a sand filter or de filter turn system off then turn multiport to back wash turn back on let run until the backwash glass is clear turn off then turn to rinse turn back on for about 20 sec then turn off then turn multiport back to filter then turn back on
Oct 20, 2013 | Pentair 1.0 Hp Whisperflo Pump
Blagdon 6250/backwash instructions
Turn off the pump.Ensure a hose is connected to drainage on the waste outlet of the valve assembly. Make sure there are no kinks in the hose.Turn the valve to "backwash" (usually opposite of filter).Turn the pump on and run for 2 min.Turn off the pump and run on rinse for 15 seconds.Repeat until the glass jar on the waste line runs clear during backwash.Return to filter. (If you have a sand filter, your done. If you have a DE filter, add the correct amount of DE to your skimmer return while the pump operates. An 18X34 pool takes about 5-7lbs.)
May 09, 2012 | Pool & Spa
A 460 engine that acts like its not getting enough fuel. Will start but runs as if only on half the cylinders missing badly or such.
Check your running fuel pump pressure. If (as I suspect) it's too low, first try changing your fuel filter. After changing the filter, recheck the running fuel pump pressure. If still low, check you fuel pump pressure regulator. If OK, you may need a new fuel pump.
Also probably would be a good idea to replace you air filter.
Jan 09, 2011 | 1990 Ford F250
Fuel filter or fule Pump?
i,d say start with filter first. if it was the pump it wil not run pump work or dont work
Apr 08, 2009 | 2003 Mitsubishi Outlander
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
59 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
