Question about Carrier 38CKC060 Air Conditioner
38CKC060 Carrier. Outdoor unit-fan does not spin, noise and very hot inside the cage!
  • 407 Answers
It sounds like your fan motor is burnt up. If the noise you are hearing is coming from the motor itself, then it's going to have to be replaced. One way to check this also is to turn the unit off and try to turn the fan blades by hand, if you cant get to it, then use something skinny and long enough to drop through the opening on top. If there is any resistance, than its difinitly a bad motor. If the noise you are hearing is coming from the compressor, then your fan motor still might have a chance and only needs a capacitor which is a round or oval part inside the units electrical compartment. Depending on how mechanically inclined you are, it is possible to fix these yourself. Just a warning though, if your fan hasn't been running and the compressor has, it can or could burn up the compressor also. This is another reason why it can be hot inside the cage. Your compressor will go into internal lockout if it gets to hot and will not come back on until it cools, but it can only handle so much. Hope this points you in the right direction and good luck!
Posted on Aug 05, 2010
What is the 38ckc060 unit is it a gas split or a condensor or a heatpump unit ?
that is a condenser, or air conditioner. cooling only, outdoor unit
Aug 15, 2014 | Carrier 38CKC060 Air Conditioner
NOISY SQUIRELL CAGE ON A CARRIER AC/HEAT PUMP OUTDOOR UNIT
Not unless its a belt driven wheel. If not no grease will help just make a big mess. Take the fan assembly out, take motor off the wheel, take wheel out of the assembly wash wheel with hose, dry reassemble. Or just go buy a new wheel but check your shaft on the motor if loose get a new motor also.
Mar 15, 2013 | Carrier Heating & Cooling
Carrier 38CKC036350 condensor fan not spinning makes humming noise compressor hot fan can be turned by hand
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Carrier 38CKC036 Air Conditioner
AC Condenser motor will stop at 1pm but inside unit is still running but no AC. If I turn the AC unit breaker unit off and then an hour later turn it back on. The unit runs fine all day until 1pm. Had a...
Hi, the tech should have been able to figure the stat out with out a manual to see why the condenser is shutting off at 1:00 P.M. This is unusual for this to happen, unless it was winter and this is a heat-pump going into defrost, but just the fan would shut down. Does this unit have a box on it that was installed by your electric company that shuts the unit off during high peak conditions in the summer? This would cause it to shut down at the same time everyday. If not, it would have to be something in the thermostat that is set for it to shut off at that time. It still does not make since, as it would shut both the indoor and outdoor unit off, not just the condenser. Are you saying that just the condenser fan motor is shutting off, but the compressor continues to run until it shuts off on high head pressure when the fan stops, or does the complete outdoor unit shut down fan, compressor and all at that time??. It sounds to me like this outdoor unit has a time delay relay that has a fault in it may be shutting it off at this time daily? Please let me know if its just the condenser fan motor that shuts off, or if the complete unit is shutting off all together, this will help .
Sincerely,
Shastalaker7
A/C, Heating,
Sep 08, 2010 | Carrier 38CKC060 Air Conditioner
Condencing fan is not spinning and very hot to the touch, the compressor is making a buzzing noise.
Check the capacitor. You can use a multimeter to do that. Also if it looks swollen then it probably needs to be replaced. Some units have just 1 that controls the fan and compressor and just 1 side can go bad.
May 23, 2010 | Carrier 38CKC060 Air Conditioner
Carrier Air V unit with loud noise
If it sounds like a scraping noise it could be the motor bracket ah broken and the squirrel cage (fan assembly) is hitting the fan housing, if it is more of a squeal than it very well could be a bearing. Very hard to guess without seeing or hearing it.
Nov 02, 2009 | Carrier Heating & Cooling
Outdoor unit fan making noise when running sounds
Bearing in fan going out. Let it run till it quits or call service tech to change motor. Fix cost about 250 to 300 dollars. russ
Jul 22, 2009 | Carrier Heating & Cooling
Carrier 38CKC060 Air Conditioner Logo
398 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
