Question about RCA Televison & Video
The blue power light flashes no pic no sound no power it is a 46" 1080p hd its only a year old this happened about 4 mounts ago '
    Problem Solver:
  • 11 Answers
Please provide the make and model number of the tv for better assistance. From the sounds of it the power supply has gone bad, usually this is the result of leaky capacitors on the power supply board. you can change these out if you open the unit and can visually see which caps are bod otherwise you will need to check each one with a multimeter. Or you may be able to find a replacement or refurb power supply board online.
Posted on Aug 04, 2010
Lacie Case Only lighting up when HD is disconnected
I had the same problem with a 1TB hard drive. The fault was caused by the casing being knocked from the computer and falling onto the desk. If the hard drive hadn't been powered up it would have been ok...
I removed the hard drive from the casing and fitted it into my computer as a slave drive, hoping to access all the music and movies stored in it. No go .. But, it's worth you fitting your hard drive as a slave and trying the same. It's worth a shot.
I took the hard drive to a computer market here in China, where I work. These guys take hard drives apart to fix them, if possible. They couldn't fix my hard drive as it had been powered on when it fell ..
However, I bought a new desktop hard drive and they were able to transfer 95% of all things from the old hard drive to the new one. The cost of transferring from the old hard drive to the new hard drive was the same as the price of the new hard drive. That specialist service doesn't come cheap ... but it can be done. I paid simply because I didn't want to lose what had taken more than a year to download.
Try fitting your hard drive as a slave to see if you can access the information on it. If not, a new hard drive and the cost of transferring your music from your old hard drive may be the only course of action left open to you
Jun 05, 2013 | LaCie Big Disk External USB 2.0 1TB Hard...
I have an rca 61" dlp tv that is about 4 years
More than likely you have a power board that is failing. Since the TV is so old I doubt it is under warranty still. I estimate it would cost you anywhere between $300-400 to repair that problem so it may be time to switch to a newer LCD TV.
Feb 28, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture, power light slowly flashes, 6 year old rear projection 55" hd
its becoze us..
why did we take a pic. if we still young 2 do it.?
Dec 31, 2009 | Televison & Video
Suddenly pic went out. Loud crackling and popping heard. Now, Blue indicator and red power light continually flashing. I think lamp. Unit 3 years old
the lamp has blown replace if got instruction book that came with tv shows you how if not got the lamp is behind cover on side or frount cover that comes off by undoing two black screws on back corners (each lower corner) anda sharp pull will remove cover
Dec 13, 2009 | JVC HD-56G786 56" Rear Projection HDTV
POWERS UP BUT NO PICTURE OR SOUND WILL NOT SHUT OFF POLAROID 37" HD LCD TV-2 YEARS OLD
my POlaroid 37" did same thing blue light stayed on no pic or sound was 2 electrolytic caps on power supply board took back off and they were noticably bulged at top radio shack sells these caps at $3 apiece fixed mine works like new saw a video on here how to do it
Dec 07, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
May 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Lacie d2 HD Quadra 250gb
Lacie D2 drives in my experience are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a blue light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure.
Hope this helps.
Dec 01, 2007 | LaCie (300770) 250 GB Hard Drive
Televison & Video Logo
123 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
