Funai flat screen television when powering on from standby colour picture & sound only lasts for seconds before tv goes back to standby no picture & no sound ?
    Sergeant:
  • 280 Answers
If it is a LCD tv it could be the power supply or inverter board.
If it is a DLP it could be a bad lamp.
If it is Plasma your in expensive trouble
Posted on Apr 26, 2008
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
How do I fix my Visio tv when the screen suddenly goes almost black and white?
Hi Evan
Essentially it's a computer inside a modern Flat Screen TV these days. Not a lot that the average person can do...
But... if you feel capable of opening the back....
Once you get inside and check for loose or poor connectors,
I would be looking for leaky Electrolytic Capacitors.
Usually in the power supply section.
Look for brown fluid leaks on PCB & a very slightly puffed out or bowed top on the cap. (ready to explode)
Take a picture of suspect. Take note of Polarity (black stripe) & write down uf & voltage & temp values.
eg 1000uF @ 25v
To prove you are on the right track, you can connect a similar rated Cap across (in parallel) the existing Cap.
Depending on space etc. Even by short extension wires.
Power up & see results. Fault Gone or Not?
Then...
Unsolder & Remove suspect Cap & try to replace with higher voltage rating & slightly higher uf capacity depending on space available around the components.
Good Luck
See
How to Replace an Electrolytic Capacitor
Oct 30, 2015 | Vizio L37 Television
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Funai TV will not stay on. It turns on for 1 second and then turns off. Red standby light blinks on and of, what can I do?
Either the power driver board is faulty, or it has a humidity sensor in it, which turns it off. Move it to a very dry place for a few days, then try it again and it might work.
Jan 19, 2015 | Funai Televison & Video
No standby light, no picture
It may be a issue with the power supply in the set---unless you are able to safely open and examine the set and the power supply take it to a shop and get an estimate.
Jun 14, 2012 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Apr 07, 2009 | Sharp LC20SH7U Television
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Funai tv
Open the back cover and check any fuse blow in Y Sustain board or Z Sustain board. If you do find the fuse gone, replace the board. Good luck!
Jan 25, 2008 | Funai F42PDME 42 in. Plasma Television
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
