Question about Kodak EasyShare LS753 Digital Camera
Kodak ls753 error#45 and lense will not retract
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 04, 2010
  • Juancg Dec 28, 2010
    Gracias, de verdad si me sirvió la orientación que leí en sus comentarios ya que la cámara me indicaba error 45 y presentaba atoramiento del objetivo ya que el lente no se retraía, pero siguiendo sus instrucciones, tomé la cámara con la mano derecha con el objetivo hacia abaja y poniendo cuidado de no golpear la cámara, golpeé fuerte mi mano derecha contra mi mano izquierda un poco cerrada para no golpear el objetivo y santo remedio después de tres intentos el lente se desatoró y la cámara quedó en perfecto estado.
Where can I get a copy of the manual?
[PDF]Kodak EasyShare LS753 zoom digital camera
resources.kodak.com/support/pdf/en/manuals/.../LS753_GLB_en.pdf
Kodak EasyShare. LS753 zoom digital camera. User's guide www.kodak.com. For interactive tutorials, www.kodak.com/go/howto. For help with your camera, ...
Sep 08, 2015 | Kodak EasyShare LS753 Digital Camera
Kodak M853. The lense will not retract, and the outer lense is crooked.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 15, 2011 | Kodak EasyShare M853 Digital Camera
How do I fix error e45 for a kodak LS753
Error # 45 means the retractable lens is stuck, possibly caused by a drop or sand or other gunk that has jammed the gears. It will cost more to have repaired than the camera is worth, so you have nothing to loose by trying this. Hold the camera in your strong hand with the lens away from you and smack it hard into the palm of your other hand (if you can't take pain maybe use the heel of a shoe) pretty hard. It may take several tries. Best results - smack camera immediatly after turning off.
Oct 14, 2010 | Kodak EasyShare LS753 Digital Camera
Camera locked - camera error #E45
Hi
www.Kodak.com says:
"E45" appears on your camera's display when your camera requires service or repair.
I think it is a lens error. They have a page on www.kodak.com called Step-by-Step Solutions and Repair. This is for USA only.
See what they suggest.
I may be cheaper just to get a new camera.
Hope this helps.
Feb 21, 2010 | Kodak EasyShare LS753 Digital Camera
Camera turns on and off but lens will not retract nor will it wor
I followed the advice of a comment and smacked the open lens against my palm. Worked like a charm. Everything works perfectly now. Hope it continues.
Jun 24, 2009 | Kodak EasyShare LS753 Digital Camera
E45 Error
turn the camera off and then on. if you encounter the same error, go to www.kodak.com/go/itg to either avail of the service upgrade program or get it repaired.
Apr 11, 2009 | Kodak EasyShare LS753 Digital Camera
Kodak easyshare E45
the lens alignment of your camera is messed up it will take service repair to fix it, it would cost you the same for a new one...
however there is an alternative solution but this seems weird it up for you to try...
try to slap your camera several times on the side of the lens or try to intentionally drop it but not to hard, drop it on a carpet or somwhere thats not hard..
google this: error 45 on kodak easyshare LS753
then choose the 5th result youll find forum about this wierd solution...
Thanks! and good luck!
Aug 10, 2008 | Kodak EasyShare LS753 Digital Camera
Camera error message #E45 camera Kodak easy share cx6330
I have fixed the problem! For any out there with a the same problem, all you have to do is smack the extended lense against your palm firmly then turn the camera back on. It just worked for me and no more error, camera is now working fine. Good luck!!
Jul 14, 2008 | Kodak EasyShare LS753 Digital Camera
Kodak ls443
#45 is a lens error code, very common problem with ls443, not much you can do, you will need to replace the whole lens assembly
Aug 22, 2007 | Kodak EasyShare LS443 Digital Camera
Kodak EasyShare LS753 Digital Camera Logo
316 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
