Question about Insignia IS-LCDTV32 32 in. Television
Turns on but nothing else happens it is Insignia
Turns on but nothing else happens it is Insignia 32" Class 720p Flat-panel LCD HDTV
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 04, 2010
How do I turn off subtitles?
Under support downloads, download manual.
You will find it under captions not subtitles.
Insignia 32 inch Class 720p 60Hz LCD HDTV
Nov 10, 2014 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Insignia ns lcd 32 wont power on
When you plug in the set, does the standby light come on? Most likely you are dealing with either a failed power supply or main board. I would start with checked the power supply for bulged capacitors.
Dec 15, 2012 | Insignia 32" 720p Flat-Panel LCD HDTV
I need to change my insignia from 480p to 720p
the set selects automatically depending on the signal it is getting.
May 30, 2012 | Insignia 32" 720p Flat-Panel LCD HDTV
Do you sell stands for Insignia 32"
You should be able to purchase a stand for your Insignia TV here. Search for your TV model number.
Feb 14, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Insignia 32" NS 32 q09
Since you don't mention how you're receiving the signal, I'm assuming you use a cable box or computer. Adjust the output settings (e.g. 720p, 1080p) on the box and then adjust your TV settings. If it's a computer, you'll need to adjust the video card settings to a compatible aspect ratio (e.g. 1366x768) for the desktop to display properly on the TV. Details can be found in the owner's manual.
Jan 04, 2010 | Insignia 37" LCD Flat-Panel HDTV
Insignia? 37 720p Flat Panel LCD HDTV will not
Power-cycle the unit (turn it off and unplug for several minutes). If you're unable to power the unit on successfully, the TV probably requires repairs. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 03, 2010 | Insignia 37" LCD Flat-Panel HDTV
Insignia IS-LCDTV32 32 in. Television Logo
64 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
