Just got a refurbished T610 in the mail. Got it set up and printing but the pages are coming out almost entirely black. Also there is a loud grinding noise that sounds like a gear slipping. Any help would be greatly appreciated.
  • toysonfireot Aug 05, 2010
    I ended up fixing this myself before reading your responses, it turns out that the company that refurbished the item forgot to attach one of the important rollers in the inside assembly. I found it loose in the printer and put it in place.
    President:
  • 567 Answers
Hi if the page are coming out black you need to check the cartridges to see if they are leaking, and the is coming from the gear,it may not be properly oil.
Posted on Aug 04, 2010
  • 10 more comments
  • toysonfireot Aug 04, 2010
    Will the indication of a leaking cartridge be on the cartridge itself? where should i check? If it is leaking, is there any way to fix that or should I try another cartridge?
  • Hilton Bristol Aug 04, 2010
    If the cartridges is you will notice ink on your hands when you touch it or will notice ink around the socket when you remove the cartridges, and if its leaking you would need to replace it,you can see the cartridges when you open the printer.
    What brand of printer do you have?
    The printer is a Lexmark Optra T610. It looks like the cartridge is leaking.
    I just tried a new cartridge and it seems to be doing the exact same thing.
    Turn the Lexmark printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
  • Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps.
  • Step 3Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
  • Step 4Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
    1. Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you’ve completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
    2. Step 6Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
    The instructions you are giving me seem to be for an inkjet printer. This is a laser printer that uses large toner cartridges.
  • Open the lid of the printer and take the cartridge out. Search for the identifying make and model numbers in bold print on the cartridge and write them down, along with the model number of your printer.
  • Step 2Place the cartridge back into the printer.
  • Step 3Have a salesperson at your local store help you find the correct toner cartridge using your model numbers.
  • Step 4Open your new cartridge at home and follow all directions on properly removing the packaging.
  • Remove the old cartridge and place it in the garbage (or in a plastic bag if you plan to recycle it).
  • Step 6Place the new cartridge in the printer, following the diagram and instructions in your owner's manual or the ones posted on the lid of the printer.
  • Step 7Print a test page. If it doesn't work, take the cartridge out and try again.
    What is wrong with your Lexmark color laser printer? Sometimes it prints, sometimes it doesn't. You keep getting paper jams. Luckily Lexmark printers aren't that hard to troubleshoot. Here are a few steps to troubleshoot your Lexmark color laser printer:
  • Be sure that everything is plugged into the proper place. This includes power cords, USB cables and server cables.
  • Step 2Check to see if there is a paper jam. Newer printers will tell you the location of the jam, while older printers require that you open them up and search for the jammed paper.
  • Step 3Be sure that your computer is networked to the printer if you are on a shared network. Open your control panel and click on "Printers." It will display all printers that your computer can access.
  • Step 4Consult your manual for specific troubleshooting tips.
  • Ask a family member to look at the printer. Sometimes we overlook a simple solution that may be caught by someone else.
  • Step 6Visit the Lexmark Web site, click on "Customer Support" and search the knowledge base section. This is a great database for specific problems, with step-by-step instructions to fix your printer and computer.
  • Step 7Call Lexmark's customer-service hotline. Have all printer information handy to talk to the representative, such as make and model number.
  • Step 8Print a test page. Make sure that everything is lined up and ready to work again.
    Optra T610
    If your printer only prints black pages it will require the high voltage power supply to be replaced. this will fix your problem
    May 01, 2010 | Lexmark Optra T610 Laser Printer
    HP2420N printer makes a loud grinding sound when printing
    This printer had change made to some drive gears. They wear down and cause this noise. If you can find a technician to replace the 3 gears it can be inexpensive. We do it for under $150 with labor and parts.
    Apr 15, 2010 | HP LaserJet 2420 Printer
    Lexmark C510 is making grinding noises while printing large jobs
    I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
    Oct 15, 2009 | Lexmark C510 Laser Printer
    Printer has set for a while. The print quality is very poor. Black is grey, there are streaks across the page.
    Take the cartridge out and shack it side to side a few times to move the toner around and reinstall it.
    May 28, 2009 | HP LaserJet 8100N Printer - Refurbished
    Our Lexmark T610 laser printer
    you have the wrong drivers for the printer. You maybe getting weird characters also. When you turn it off it clears the memory buffer (print job). I assume it seft tet OK. Delete and reload drivers
    May 11, 2009 | Lexmark Optra T610 Laser Printer
    Always prints more to left than established margin
    Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
    Hope this helps. Bud
    Jan 08, 2009 | Lexmark Optra T610 Laser Printer
    Product HP PCS 1510 All in 1 printer. This morning, I head some loud grinding as the last page was printing. Now I get loading errors every time I want it to print, but no more grinding sounds.
    There is sure sum jamming in your printer,, clean the roller and check the data cable connected to cartages may be that cable is comes to the way while printing.
    Nov 28, 2008 | HP Office Equipment & Supplies
    Konica magicolor 5430 smuding all over page
    also there can be problem with the waste toner pipes, that the waste toner wont go away and smug the page. check waste toner box also check transfer belt and pc drums that they are clean.
    Jun 03, 2008 | Konica Minolta magicolor 5430 DL Laser...
    Canon MP530 Makes Grinding Noise when printing starts
    I had this same problem and called tech support. Instead of sending a new printer they had me
    1 remove print Cartridges
    2 remove print head
    3 replace print head
    4 replace print Cartridges
    5 unplug power from the wall
    This seemed to fix the problem.....for me anyway.....for now.
    hope it helps
    Dec 15, 2007 | Canon PIXMA MP530 All-In-One InkJet...
    Open Questions:
    k24674
    jasbo
    jasbo
    Marvin
    Marvin
