Question about Troy Bilt Tb70ss Gas Trimmer
Have a tb525ss weed eater broke throttle trigger and spring cant seem to figure out how to put spring back in
SOURCE: I have a Troy Bilt TBP6040 XP 4 cycle weed eater
I just had this same issue. I found out that you have to take the cord out of the handle then put the spool in. You then rotate the spool back in and align the spool with the spring and fish out the cord which will put a small amout of tension on it. You keep the tension on it and put the handle back on.
Rgds,
Mark J
Posted on Jul 23, 2009
moretons
  • 155 Answers
SOURCE: Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Posted on Jul 26, 2009
SOURCE: i have a weed eater twist & edge rte115 cant
how to string a weedeater/rtc115c
Posted on Jun 06, 2010
  • 403 Answers
SOURCE: My craftsman SimPull 32cc weed
are you switching it from choke, to run ?
Posted on Apr 16, 2011
SOURCE: Tryingto replace my troy built weed eater's head
clean grass off between shaft and the top of the head. hold weed eater still and turn the head, looking between the shaft and the top of the head. There will be what looks like a hole. Place something there that will keep the shaft from turning, then twist the head off.
Posted on May 25, 2011
Stihl fs 85 weed eater trigger replacement
Take a look...
This may give you a little guidance?
also check here for all things Stihl...
Stihl Trimmer Throttle Outdoor Power Equipment
And this video...
And you may find this useful...
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/FS80_85_Manual.pdf
Jun 10, 2015 | Stihl FS 85 Weed Eater
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    The spring has to go inside of the trigger it is on a sears bushwhacker weed eater
    The CIRCLE goes into the Housing, then the Trigger, Make sure the Trigger SPRING is ABOVE the Pin in the housing
    Apr 07, 2013 | Garden
    I am trying to put a throttle trigger on my weed eater it's a stihl fs55c I can't figure out where the spring goes its been broke awhile I took it apart but I can't remember how it goes I...
    with the trimmer engine to your left and the shaft to your right the trigger spring goes on the peg that holds it in the body like an L. It is going to be difficult to explain exactly how to do it and the pics I get from my phone are way to large to post here even after changing the resolution
    Mar 30, 2013 | Garden
    Poulan prolink pp335 wont start
    In case anyone else hits this question, I had this weed eater and all of the attachments. I had it in my garage for a good 7 years, and it had gas in it 7 years ago.. I've known for some time that it now had no gas in it & that it wouldn't be easy to start if it worked at all.. I put some normal gas in it and dripped a bit of oil into the gas because i didn't have a can properly mixed and didn't want to oil up my lawn mower gas.. I had a guy cutting my lawn for the past 7 years but he recently disappeared..
    I primed the weed eater and attempted to start it for a good 20 minutes yesterday to no joy.. I put it away and figured i'd try it again and more in depth today when I had more time. I wanted to take the spark plug out and make sure it was clean, etc.
    On attempting to remove the spark plug, I couldn't find a wrench or socket that would work to do so, so I just reconnected spark plug cable and figured I'd give the pull start method another try.. I pumped more gas into the primer and attempted to start it normally a few times.. It wouldn't even attempt to fire. Just for fun since I was going to have to throw this and tons of never-been-opened attachments away, i decided to try something goofy (in my opinion) and squeezed the trigger as far as it would go (which disengages the choke feature..) and gave it a few pulls on the cord.. It attempted to fire a few times, then it fired! It worked very well although it was a little bit thick on the smoke for a bit..
    Maybe this answer will help someone else who hits the problem of leaving gas in a weed eater for years.. don't use the choke feature to start it.. start it at full throttle with the primer perhaps flooded a little bit..
    Apr 01, 2012 | Garden
    Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
    you may have wound the spring backwards, try winding the othe way.
    May 09, 2010 | Garden
    I have a Troy Bilt TBP6040 XP 4 cycle weed eater with the spring assist starting. The pull cord broke and I am trying to replace it but I can't seem to get the cord to go all the way back in. I need help....
    Rgds,
    Mark J
    Apr 16, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
    Troy Bilt Tb70ss Gas Trimmer Logo
    554 people viewed this question
    Top Troy Garden Experts
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Wade Mobley
    Wade Mobley
    Are you a Troy Garden Expert? Answer questions, earn points and help others
