Question about Peg Perego John Deere Gator HPX Ride on Toy
Battery is charged but there seems to be a problem with the pedal
    Genius:
  • Peg Perego Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Posted on Jun 13, 2012
Battery seems flat with a constant clicking noise inside the car after the ignition is off
If you have a multi-meter check the battery voltage at the terminals of the battery 12 v dc or better indicate that the battery is nearly fully charged.
no meter no problem. Turn on the head lights and look into the light and if the light is dim and flickers the battery is either weak or needs a charge. If the car will not start and you are able remove the battery and take it to Auto Parts store of choice. Have them do a full diagnostics. They may need it for a while to recharge the battery before checking. If battery is bad replace. If not charge battery and take car to favorite garage. Remember not to depress the gas pedal after battery disconnect. If you do the engine electronics will have to relearn idle. Some times the engine will continually stall during the relearn process. Better to leave the pedal alone during battery replacement.
If the car starts take it to a Auto Parts store and have them check the battery and charging system.
I expect that a CD is stuck in the radio or a light switch was left on
  • Dome
  • Fog Light
  • Head Light
  • Brake Light (bad switch)
  • Flashers
  • Cooling fan thermostat (bad thermostat)
What has happened is that the battery has run down and as the battery sits for a few seconds voltage comes up and light goes on. With light on battery voltage goes back down and relay clicks. Of course this will discharge the battery.
Dec 08, 2015 | 2009 Ford Escape XLT
Hesitation on acceleration
renew the petrol filter . and battery charge .
Nov 06, 2013 | 2007 Dodge Nitro R/T New Cars
1988 Honda Accord lxi has issues starting. Ignition, engine, starter, and most everything seems okay. Have not checked o2 sensors and getting new plugs after cleaning old ones and reinstalling them. They...
COULD BE LOOSE ALTERNATOR BELT.TRY ADJUSTING ALTENATOR BELT SEE IF HELPS PROBLEM.IF ALTERNATOR NOT CHARGING BATTERY THE ECM CANT WORK NONE OF ENGINE CONTROL SYSTEMS.IF ALTERNATOR DRIVE BELT TENSION CORRECT REMOVE ALTERNATOR TAKE TO ANY AUTO PARTS STORES THEY WILL CHECK IT OUT SEE ITS WORKING OR YOU CAN TAKE DIGITAL OR ANALOG VOLT METER TO CHECK ALTERNATOR OUT PUT AT BATTERY WITH ENGINE RUNNING SHOULD HAVE 13.5 - 14.5 VOLTS IF ALTERNATOR IE CHARGING THE BATTERY.
Jul 23, 2011 | 1988 Honda Accord 4 Door
I got a Little Tykes Junior Quad given to us and the lights, and all buttons on the front work fine. There is no power to the pedal though. Would it be that I need to replace the power pack? I know the...
You should have a battery charger to charge the 6v battery that powers the wheels, your first step should be to make sure this battery is fully charged, its located in a compartment under the seat.
Jan 01, 2011 | National Little Tikes Junior Quad
Something in my fuel pump is draining my battery and the van wont start. Meaning this I charge up the battery to start the van and the van will turn over but not fire (start) I replaced the fuel pump...
could be a bad ( tps ) sensor it registers the amount of pedal you give it so it knows how much fuel to give the engine if the starting volts are not where they should be it won't start.
Jan 20, 2010 | 2002 Kia Sedona
Does not run when I push the pedal, it is brand new and has run once for 2 hours on an 18 hour charge, called PP and they told me to move the red pedal wire to the blue location (bypass) nothing happened....
OMG! The exact same situation here! Bought through Amazon, no warranty. I am so bummed. It was rode 5 times by a five year old on flat ground. Now it is a brand new, non operational, made in China piece of $500- junk! I am furious!!!When you press on pedal, nothing happens, fully charged battery, etc. Volt meter even confirmed fully charged battery. What ever happened in your situation? I am so hesitant to buy other parts, or send it here, to put more money into an overpriced piece of ****. Way to ruin Christmas!
Dec 02, 2009 | Polaris 800 Twin Sportsman Ride on Toy
Doesn't always turn over
It sounds like your battery isn't holding a charge. Regarding the starting, you may have to replace your starter solenoid. Although many cars do not start if the brake pedal is not depressed, the thunderbird is not one of them. I have one outside in my driveway right now. There are unfortunately, numerous electrical glitches with 89-94 Thunderbirds. I have replaced many many electrical parts for both of mine (a '90 v-6 and a '94 v-8)
Jul 13, 2009 | Ford Thunderbird Cars & Trucks
LIttle Tikes Hummer not working
Sometimes if the battery is not charged up and it sits for a few months then it is difficult to charge the battery. I learned this the hard way by keeping it out all winter without charging up. I called the repair tech's at this website http://www.shopjandl.com/kids---baby-ride-on-toys-little-tikes.html
they told me to charge the battery up for 18 hrs at a time, especially if it sat more than 3 weeks.
If the battery is good it may be the foot pedal in this link http://www.shopjandl.com/mepu0001.html
May 09, 2009 | National Little Tikes Hummer Yellow
2007 Dodge Caliber
Make sure you have a fully charged battery. When starting the car, push the gas pedal down to the floor to engage the choke. Then push pedal halfway down and turn the ignition. Try jump starting to see if it is the battery. If it still turns slow it may be a bad starter.
Jan 22, 2009 | 2007 Dodge Caliber SXT Sport Hatchback
Peg Perego John Deere Gator HPX Ride on Toy Logo
37 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
