Question about GPS
I own a 2010 Nissan Maxima and I misplaced the manual(lost). My bluetooth hooks up but I want to be able to say "CALL HOME" or "CALL DAVE" without having to say the phone numbers.
  • 3,289 Answers
Dave,
Not knowing which GPS you have (factory installed or aftermarket Garmin, Tom Tom, Magellan, etc.) nor the particular cell phone you're using - it will be pretty hard to give a reliable answer. Suffice to say, your phone must be able to support the type of dialing that you are trying to do. If it does not, no amount of high-tech Bluetooth (BT) accessory (built-in or otherwise) will enable it. The entire set up will only work as well as the weakest feature set in the devices - be it the GPS, BT or Cellphone.
If however, you have verified that all components of the system support the type dialing you want, it may just be a simple firmware update for one or more of the devices to get it to work. You'll have to check the firmware revision levels of your hardware to check against the latest version(s) available. You may have to use a combination of sources - depending on who the manufacturer of the components are. Factory installed GPS systems may require a trip to the dealer - but the cellphone and non-factory GPS devices can usually get updated via internet, wireless or USB cable.
If you can provide the names / model number / manufacturers of the devices involved - create a new query for some device specific help from users here.
Please rate this reply if it was helpful - good luck!
Posted on Aug 04, 2010
Why can I not open the doors on a 2010 nissan maxima?
Its doors may be hooked up and jammed.
you have to use WD40 to make it smoother and then try after a few minutes
Nov 12, 2016 | 2010 Nissan Maxima
95 Nissan maxima no heat
HELP!! No Heat Only cold Air - Maxima Forums
maxima.org/...maxima-1995.../575092-help-no-heat-only-cold-air.html
Oct 30, 2008 - Ok this is the deal i have 95 gle auto climate control. its soo dam cold here in ... its was low filled it still no heat when i was messing with the climate control i was setting .... 1999 Auto Nissan Maxima SE-Limited Crimzon Blaze Bad Engine Coolant Temp Sensor=No heat?
Dec 11, 2010
coolant change - no heat
Nov 28, 2010
No in cabin heat & engine overheating
Dec 6, 2009
whats the cause of getting no heat?
Feb 14, 2003
More results from maxima.org
No heat,
Jan 15, 2016 | Nissan Maxima Cars & Trucks
How to replace the abs speed sensor 2010 nissan maxima
Each wheel has a sensor on it. You have to determine which sensor is defective then separate the plug on the sensor from the sensor then unbolt the sensor from the wheel.
Sep 01, 2014 | 2010 Nissan Maxima
Does the 2004 nissan maxima has a bluetooth
Hi Yadira,
Yes it has a bluetooth capability Tony. Based on the article about 2004 Nissan Maxima: The extensive list of high-tech options offered includes a navigation system and Bluetooth integration. The iPod interface is probably the most praised feature by consumers.
I have this video for you on how to bluetooth pairing. Also I have a site about 2004 Nissan Maxima.
2004 Maxima Nissan
May 08, 2014 | Rostra 2004-2006 Nissan Maxima Bluetooth...
I have a n iWave bluetooth headset that came without a manual, I wuold like to know how to get it to work with my I PHONE 5.
I have another device and I want to connect my iwave wraparound ear buds to, but I misplaced the directions and code?
Feb 25, 2014 | Yamaha YBA-10WH Bluetooth Wireless Audio...
2010 NISSAN MAXIMA SV
Hi,here's a link to a owner's manual,look at section 2-24 for security code,I read it and it says you can only arm your alarm with your fob,doesn't do it by itself. https://www.nissanusa.com/pdf/techpubs/maxima/2010/2010-Nissan-Maxima.pdf
Jun 24, 2017 | Nissan Maxima Cars & Trucks
Connecting cell phone to 2010 nissan maxima bluetooth.
I mal ooking for help with the exact same issue
Oct 18, 2009 | LG Vu CU920 Cellular Phone
I hooked up a new radio in my 96 nissan maxima and get no sound.
Hook up the Amp Turn on Wire usually blue/white strip
Feb 21, 2009 | 1996 Nissan Maxima
GPS Logo
106 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
