Question about JVC HR-S9500 S-VHS VCR
Unit won't turn on, goes into standby, flashing "auto"
Hello - unplugging my unit for several hours yielded no results. Can you offer any other suggestion to remedy the problem. The VCR will turn on only long enough to accept a cassette. Thanks.
  • 979 Answers
The mechanism is not "shutting" when power is applied. This step is necessary for the unit to operate. Would suggest a complete belt replacement and cleaning....accordianman
Posted on Apr 26, 2008
I can't turn demo mode off or Standby from flashing on my Sony CMT-MX550i, can't turn unit off without unplugging it.
Sony CMT-MX550i -- I had good results by pressing the "TIMER MENU" button on the remote and simply setting the time. After that, no more demo.
Jan 16, 2013 | Sony CMTMX500i Desktop Micro System
I have a Denon AVR1603, recently I plugged computer in AUX connections at rear (not loud) and it kept tripping out. Eventually it tripped and now the the on/standby light fashes but nothing else happens....
The LED flash indicates that unit goes into protection. Check the power transistors, the 0.22 ohm or 0.47 resistors in the output of the transistors.
SAM ANDERSON
Sep 29, 2008 | Denon Audio Players & Recorders
Picture on my Toshiba 37RV753B has gone off and the standby light keeps flashing yellow. It was working ok a few hours ago, but I switched it off to go out and now it won't work. It's only just over a
Hello!
If you have used your TV 24/7 for the past year, the issue might be in the power supply. If there are "bloated" capacitors, set will not start up. If you haven't unplug it for a year, it might be staying alive. Once you unplugged the set, those capacitors won't let your set back to normal. That's a big project and requires technical background. If you think you can handle that, open your TV set and inspect TV's power supply board. It will be located near power cord plug or wire. Also, it might be covered by tin shield, which must be removed for further observation. If you see any "bloated" electrolytic capacitors, replace them with same value and voltage. But it might be main board's issue, as well. what is your place's ambient temperature? If it's lower, than 75F, try to warm up the back of the set, before even trying to poke it open. Use hair dryer. First, point it on main board's in/out connectors. Do not overheat! Few minutes might be enough. Then, try to plug the set in and observe the behavior. Any change? turns on? Main board is bad. Same with power supply. If heating up main board area does nothing, try power supply area. If it makes a difference, start looking for bad capacitors.
Good luck,
Let me know results.
Thanks,
Alex.
Dec 10, 2011 | Toshiba Televison & Video
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
13 blinks on standby light
If you can post a few pictures of the boards in the unit to our forum at: http://www.ccl-la.com/forum/index.php Our techs will look over the boards and offer information to guide you in the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 13, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
No picture or sound, standby led flashes 11 times when first turned on after AC plug has been removed and reinserted into the AC outlet. Every attempt to turn on after the initial attempt yields 6 flashes...
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The flashing LED is justa coincidence I would think.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | Sony KP-53HS10 TV
Standby light stays red and will not turn unit on.
Try to reset the macroprocessor. Unplug the unit from AC, hold both buttons SPEAKER A and SPEAKER B and plug the cord in outlet. After display flashes several times release the buttons. No result? - repair shop.
Apr 05, 2009 | Denon AVR-1906 Receiver
BRAVIA KDL-V32A12U PICTURE LOSS
THREE Blinks
supply circuit, check T603 and R672.
FIVE Blinks
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
JVC HR-S9500 S-VHS VCR Logo
377 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
