Question about LG 42LC2D 42 in. LCD HDTV
The remote is not working we replaced the batteries and the remote make the tv go all crazy .. we can operate the tv fine with out the remote.. is there any way to tell if any of the buttions are stuck or what caused this to happen
  • LG Master
  • 8,457 Answers
Try website like Remotes.com to buy an exact to the original remote for the replacement.Most remotes these day are totally seal,can't be open.Dose ur remote have screws on it back cover,take the battery out some time a screw there too.Take all the screws out,take the remote aparts.Clean PCB board and the plastics inner rubber film's with some Q tips dipping in with some rubbing alchahol.Clean the PCB board and inner rubber film for batter contact,might save the remote.If the main CPU processor is not dead.
Posted on Aug 04, 2010
Remote No Longer Operates the BluRay Player
If you have tried battery removal and reinstallation/replacement it may be necessary to replace the remote
Nov 04, 2012 | Pioneer New Original VXX3379 Remote...
My remote for my LT55164 just stopped,,,working. Have reset tv (unplug for 20 min) Driving me f'ing crazy
To troubleshoot the remote control problem, follow this step. 1. Check the battery (new if possible) 2. Get a ordinary radio then scan the radio to no signal frequency...just a buzz song will be okay. 3. Try to point your remote control in front of your radio, then press any keys (numbers or anything) 4. If you heard some sound to the radio while pressing the keys 4.a Your remote control is working fine. 5. If you did not heard anything while pressing the keys 5.a Your remote control is not working. You need to replace it or just buy a universal remote control (cheapest way to do).
Thanks. Hope this helps.
Mar 09, 2011 | Mitsubishi MR150 Remote Control
I have 2 dish remotes #103602. One works fine the other suddenly will not allow any of the lights except TV to come on. It will not let the SAT button light up. The remote will control the TV but not...
bdmills04
Have you replaced the batteries in the remote that is not working. If batteries are low, the lights will still light up but will not operate the functions for the remote. When you press and release the SAT button, what happens? If you try to press the SELECT button, does the TV button light or the SAT button? If you have already tried these steps, you may need to readdress the remote to the receiver. I have provided a link with the instructions on readdressing the remote. I hope this helps.
Readdressing the remote, step 5:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Aug 18, 2010 | DISH Network IR Remote Control
Wii curser or pointer jumps around
There are a few conditions that you need to check:
  • Batteries fully charged or at full power
  • Wii remote is aligned properly.
If the batteries are dying, that might be a cause of the jumpiness because it'll have trouble maintaining a signal lock with the sensor.
Make sure you have the sensor in the right place (above or below the TV as you specify in the settings).
Make sure you have the Wii remote sensitivity settings correct too. All of these things are in the settings menu.
Feb 08, 2010 | Nintendo Wii Console
No remote control operation of TV
there is some probelem with tv so call its service center and repair it.
Jun 21, 2009 | Panasonic CT25G7 25" TV
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
REMOTE OPERATION
Looks like a common frequency and coding problem. Try to keep the TV and Cable box far away and try the remote. If it works, then, escalate to Cable operator for providing a new box with remote or ask for a different brand of cable box.
Jun 10, 2008 | Protron PLTV-37 37 in. LCD Television
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
LG 42LC2D 42 in. LCD HDTV Logo
37 people viewed this question
