Question about Hotpoint Aquarius WF000 Front Load Washer
Machine has power, will fill up with with water but the drum dosent move , it will drain buy will not spin.it it worth being repaired?
  • 21 Answers
THIS SOUNDS LIKE THE BELT HAS COME OFF. EASY TO FIX YOURSELF IN 15 MINUTES
Posted on Aug 04, 2010
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
Samsung WF7700N6W1 washing machine not draining
Could be a sock or something between the 2 drums that moves over the outlet hole from the drum when upright and trying to drain but moves away when machine is on its side. Get a flashlight and look through the holes in the inner drum and you may find the culprit.
A coin may also be stuck in by the pump blade, not always easy to see but worth a look.
Dec 22, 2012 | Samsung Washing Machines
Drain pump keeps running
Probable motor control board problem.
don't buy a GE anything!
May 03, 2010 | GE WBVH6240F Front Load Washer
My washer fills up, but not inside the machine. If I put the machine on spin, the water drains out. Why won't it fill inside the machine?
The water is going into the machine, but somewhere below the inside drum. I can hear it sloshing around if I move the inside drum. If I put it on the spin cycle, it does not spin, but the water comes out of the hose and into the sink.
Nov 09, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Water will not drain and drum will not rotate to spin
check your led switch..it is probably brakes off.... easy to buy and replace..unplug washer, take top conrol panel off...check your led switch...give me you email i will send you wirring diagram
Aug 29, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet Washer Leaking
Hi, If you are getting water in the washer without it running, the inlet mixer valve is going bad. When you run a load, does it finish spinning and all the water is out? I hope this helps you. It is not an expensing repair. I can walk you through the repair if you would like.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
51 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
