Does automatic zig zag machine mean it can't do straight stitch?
Simplicity 8220, I also can't figure how to thread it. Manual on web is $17, I only paid $10 at garage sale.
So your set up to sew zig/zag and only get the zig or the zag : )
Could be top thread tension is too high. Switch to a straight stitch and reduce tension until top thread starts to appear on bottom. Then go back to zig/zag and see if it sews properly.
If still dropping stitches, check the needle is not bent and is fully inserted into the holder. Clean the bobbin, hook, and race per machine instructions. Try reducing the stitch width and see if that makes any difference. If still not right then timing may be off.
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
You don't say the make and model of sewing machine. But generally zig zag is achieved by selecting the zig zig stitch on the stitch selector, then setting stitch length to 2 and stitch,width to between 3 and 4, depending on the fabric. If its a very light weight fabric 4 the thread will pull in and tunnel the fabric so turn down to narrow the width of the stitch.
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
