Question about Refrigerators
Test button on a eurocave...what does it do? - Refrigerators
Replacement power cord for Eurocave wine art
Fixya does not sell replacement power cords.
Oct 10, 2016 | EuroCave Refrigerators
Excess condensation in my eurocave 266
Check the door seal gasket is sealing without any gaps. Check the ambient temperature isn't too high, and check the condenser is clear and aired.
Apr 20, 2014 | EuroCave Comfort 266 Connoisseurs Package...
When plugged in, the compressor doesn't activate. When you press the test button, the compressor turns on. After doing that about fivetimes, the compressor won't even flip on? This is a Eurocave Model...
if you keep starting it it will quit any way . but this sounds like a start relay or a bad or run cap / but you could have a bad compressor also . and if running on a long ext cord it cause this problem so ck these / hope this has helped mm feed back pls ..
Nov 25, 2010 | EuroCave S256T Wine Cooler
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
It's likely that you need to change the filter. Have a look at this post: http://blog.wineenthusiast.com/2009/04/20/caring-for-your-eurocave-3-simple-steps-towards-long-lasting-wine-protection/
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Eurocave Repair
can you tell if if it's running by putting your hand on the compressor,then we can go from there
Dec 17, 2008 | EuroCave Comfort 260 Collector's Package...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
