Question about Garden
The red wing nut has come off and dont know where to get one from
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Wing nuts can be purchased in the specialty hardware section at Home Depot or Lowes. Ask one of the workers for assistance.
I hope this helps.
Posted on Aug 04, 2010
1996 buick park ave replace air filter
Dave, Under the cover is he air filter, If wing nut are seized or broke, soak threaded areas of these fasteners with a penetrating oil, a few times over a day. You may have to use pliers/vise grips if wing nut is damaged. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Under Hood Bath GM Forum Buick Cadillac Chev Olds GMC Pontiac chat
How to Remove Rusted Bolts
How To Remove Rusted Screws Nuts Bolts In 10 Easy Steps
Jul 31, 2016 | Cars & Trucks
I have a reece 101 buttonholer sewing machine and whant to learn to adjusted for diferent type of buttonhole
on the head there is a plate with some letters or numbers on i need to know what they are. there is a wing nut usually on the right hand side that adjusts the length. if your machine is equipped with a tail that is adjusted just behind the wing nut a 1/4 hex nut.
May 12, 2012 | Sewing Machines
Hitachi 60fx32b out of focus how can i fix it
If not a convergence issue: each tube (back of set) has a large black lens with a wing nut on side----loosen nut and rotate lens slowly until red is in focus.
Feb 19, 2012 | Hitachi 60FX32B 60" Rear Projection...
The wingnut has been undone and now will not go back in, it wont tighten at all. Any help appreciated!
You need to remove the screw from the black cap over the wing nut this will then lift off. There is a spring under there so hold the cap as you remove the screw and lift up slowly. There is a screw in the back of the wing nut to stop you from winding the wing nut out completely. This can partly wind out stopping the wing nut winding in. If the problem is more then that you'll need to take the wing nut and the plastic block it screws into out and take it to a local workshop to get it re threaded.
Oct 26, 2011 | Bugaboo Baby Gear
I have a bugaboo wlth the white colour brake and have just found out that the white colour ones are out of date. my question is does anybody know if i can get it changed over to the red one and how much...
Bugaboo don't sell parts as such but they sell the chassis. It will coat you around a third of the price of a new Bugaboo. The new Red brake lever chassis has the lever extension handle locks instead of the wing-nuts and rocker style buttons for the handle release. Your old frame will be quite sort after on eBay. I like the rocker handle release and the extension levers are quick to use and look better but I must warn you the old wing-nut system held the handle better and if you bump down a lot of stairs the new lever system is more prone to slipping, macnutz_16.jpg
Nov 21, 2010 | Bugaboo Cameleon Jogger
I am trying to change a headlight. I can't can not
The headlight assembly (1993 Grand Caravan) is held in place with three plastic "wing nuts" that rotate on the ball-end (front end) of the adjusting screws. One "adjusting screw" (the one on the bottom, inboard side) is not for adjusting, just for mounting. The other two adjusting screws take a torx T15 in the front end of the screw.
Removing the headlight assembly is somewhat of a trick - it seems like it takes a special tool to reach the "wing nut" and turm it 1/4 turn (90 degrees) CLOCKWISE (so the "wings" are vertical). When all three of these mounting "wing nuts" have the wings vertical, the headlight assembly just pulls forward and off these mounting nuts. Place the new assembly back over the "nuts", turn the 3 "wing nuts" another quarter turn, and the new unit is mounted. Probably not even a need to re-adjust the headlights, but you should check.
The PROBLEM, is that it appears to take a special tool to reach and turn these wing nuts without breaking them (yes, the old ones get brittle). I tried a socket (did not work), and then long needle-nose pliers (broke one wing nut), then a 1/2" open-end wrench (which at least worked). However, pushing the new assembly back over the wing nuts, I broke another wing nut. So, I broke 2 of the 6, and one was broken when I started.
Now I need to find replacements for these "wing nuts" ... any ideas where to get them?
Of course I can use some washers, some nuts to fit the fine-threaded adjustment screw, and some sort of bushing (maybe cut a short piece of rubber tubing to fit over the adjustment screw). Place double nuts (second nut to lock the first in place) and a washer, then the bushing onto the adjusting screw, then the headlamp assembly onto the bushing, then add another washer, and two more nuts (not too tight) to lock it onto the adjusting screw (which must still be free to rotate). Repeat for each of the 6 mounting points. I have not tried this yet, but ... it should work.
Fabricate a tool to turn the "wing nuts" using a piece of 3/8 inch ID tubing which you file or cut 1/8 inch by 1/8 inch notches on each side of a diameter line.
Apr 22, 2010 | 1993 Dodge Caravan
How do you change a headlight on a 2001 oldsmobile silhouette??
I don't know if you mean the headlight bulb, or the headlight.
When you open the hood and look at the headlight assembly. At the top between the turn signal there is a black plastic wing nut. Unscrew that wing nut to remove the side marker light. After removing that nut persuade it to slide forward. That's the only thing that locks it in. Untwist the socket to replace the turn signal bulb. Since that is out now...There are two more Wing nuts just like the first one that hold the headlight assembly in place. (The black plastic piece the headlight is mounted to) Remove these two wing nuts and lift up on the whole assembly. Those are the only things that lock it into place. Once you slide it off the studs the wing nuts were on. Unplug the plug from the back of the light (use a flat screwdriver to lift the tab a little). Twist the round plastic ring that holds the bulb in. The bulb should pull out now. Don't touch the new bulb with your fingers as it is a halogen bulb and the oil on your fingers will cause a hot spot on it, causing it to fail SOON. If you happen to touch the glass part of the headlight bulb, clean it with rubbing alcohol. Reverse the steps...go eat dinner.
Feb 27, 2010 | Oldsmobile Silhouette Cars & Trucks
Left brake light not working. Do not know if I can simply remove the red plastic cover or must remove nuts from inside trunk. Hope it is the former.
hi inside the trunk pull back the trunk liner and there will be 3 maybe 4 plastic wing nuts remove them then remove the tail light assembly then change the bulb should be a 3057 or 3157 and reassemble
hope this helps
Nov 07, 2009 | 2006 Buick Lucerne
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
I dont know how to lower the spare tire
There is a cover in the back by the licence plate, open it and put your truck key in the slot, then put the stright pieces of steal that came in the kit( side of bed) together, and you will need to crank the spare wheel down. Hope this helps
Mar 20, 2009 | 2005 Chevrolet Avalanche
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
