Question about Craftsman Garden
I have a 2000 craftsman riding mower with a 46 inch deck and a 22 hp kohler engine. I have replaced my deck drive belt several times because it keep jumping off. I then noticed that when I installed the last one, the belt was not even from the motor to the deck causing the belt to wear very quick on the bottom from being uneven. I also have an electric pto therefore i could not lower the pulley to make the belt run evenly from pulley to pulley. The only time the pulleys are lined up evenly is when the deck is in the raised position. Thanks for all the help.
    Problem Solver:
  • 10 Answers
U could have a bent pulley ..
Posted on Aug 04, 2010
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Aug 11, 2015 | Craftsman Garden
How to change drive belt on a xl 468 lawn tractor
remove mower deck and crawl under the tractor and go at it .
Jun 08, 2015 | Toro LX468 46" 22-HP Kohler Lawn Trac...
What is the belt configeration for a Craftsman 917.254214 ride on mower?
This video shows several belt patterns for various mowers. I am assuming you are wanting the deck belt and not the drive belt. 4 seconds into the video is the standard craftsman 42 inch belt path. The belt at the bottom is put on the engine pulley. Tip from my own experince make sure that the belt is under the belt guides or you will ruin a belt in short order. Your model number is under the seat and is also a scanable barcode. Another tip is to snap a photo of your model numbers. This is handy when you need parts. More accurate and readable than writing it down. Riding Mower Deck Belt Diagram DIY
Jan 12, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you change the arbor bearings on an simplicity regent with a 50 inch cut?
You must take the blades and belt off and the well as pulley, the arbor is replaced as a unit and it unbolts with several bolts.
Jul 28, 2014 | Simplicity Regent Riding Mower 23 HP...
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Find replacement belt for LT 2000 17.5 HP Kohler Engine
WHICH BELT ARE YOU LOOKING FOR A LOT OF AUTO PARTS STORES WILL GET THEM FOR YOU OR ORDER ONLINE. GET THE MAKE AND MODEL AND SERIAL FROM TRACTOR , BELTS SRE NOT HARD TO FIND
Sep 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 18hp Kohler engine. What is
there is no clutch drive belt needs replacing cost of drive belt $20.00
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The mower deck doesnt stay kicked in
1) check condition of deck drive belt
2) check condition of belt tensioner system located on top of the deck.
tensioner system pivots and also applies brakes on spindles
being worn, it does not give full travel to tension the belt
3) make sure engine mount bolts are tight
4) engine 'Stack Pulley' groove can be worn
5) check idler pulley bearings
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Jun 15, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
248 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
