Question about Exercise & Fitness
V fit E1 treadmill fault - Exercise & Fitness
    Champion:
  • 218 Answers
Check the reed sensor also known as the speed sensor. It is located on the front roller pulley. It is mounted to the frame and looks like a small black tube with a wire attached to it. What you need to do is to check if it is good by using an ohm meter.
1. Unplug the reed sensor
2. Place the red and black leads on the two wires
3. turn the flywheel so that the magnet (should be mounted on the pulley)passes by the sensor(make sure the sensor is only 1/8" away)
4. the meter should show the sensor opening and closing if it does not recheck the gap from the magnet and if it is good, replace the reed switch.
5. The other possibility is the magnet fell off the pulley and in this case you will need to superglue it back in place.
Thank you for your question and I hope this helps.
Posted on Aug 11, 2010
  • jlam247 Oct 08, 2010
    Your magnet is not aligned properly. Check here for solution: http://fixmytreadmill.blogspot.com/2010/...
3 Suggested Answers
SOURCE: I have a horizon fitness, Quantum II treadmill.
im having this problem too if some one could email me how to fix it @ djbense@hotmail.com
cheers
Posted on Feb 26, 2010
ercupa190
  • 12223 Answers
SOURCE: v fit pst 04 treadmill error e1
Dear Sir:
Hello, i hope you are o.k
Please check this:
Most of the time, the problem in electronic code: E001 with the treadmill is:
VSD(Variable speed Drive, microchip failure). You must call to the factory and return the PCB assembly for the fix the factory.
The reason is that they have the code in the EPROM, and only them can fix and this case.
In short a recomend that you call to the factory and proceed.
After that when you have fix it your problem, I Strong Recomend to buy and install a Regulator Voltage is cheaper about us$15,00 aprox.
Thank you in advance, and hoping that you resolve, sincerely. Blessing. E.CUADRA Managua, Nicaragua.C.A.
Posted on Sep 26, 2011
Fault on treadmill saying E1 been told its batteries were are they situated on machine
Here is a link to the manual. http://gymstore.info/manuals/upload/Star%20Trac/star_trac_7600_pro_om.pdf
You might want to try the troubleshooting procedures on pg 47.
States if error code appears, "Call your dealer or Star Trac at (800) 503-1221, or USA 1-714-669-1660 for service."
Mar 02, 2015 | Startrac Fitness Products Star Trac Pro S...
I don't have users manual for pro fitness tread mill keep getting a fault saying E1
https://www.google.co.uk/search?q=Star+Trac+Pro+S+Treadmill+manual&ie=utf-8&oe=utf-8&gws_rd=cr&ei=-N_0VMutKufR7Qb_-IHgDw
youll find the manual
here is the service manual and maintance details you need to do
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20ProTread.pdf
Treadmill works for 30 seconds and then stops saying E1
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Oct 05, 2010 | Startrac Fitness Products Star Trac 3900...
After starting the treadmill 10 seconds later E1 apears on the display
Your problem is that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Sep 16, 2010 | Horizon Fitness Merit Fitness 725T...
My treadmill is showing an E1 error code, what does this mean?
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it child's play: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 07, 2010 | RTO Lifespan TR1000TV - TR1000 With A TV...
I have a v-fit kik-036-11 and keep getting e-1
Your problem might be a magnet that has fallen off from within the treadmill. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jun 02, 2010 | Exercise & Fitness
Exercise & Fitness Logo
2,486 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
