My tv have these strips runing throught the tv picture I would like to know how to remove them.
    Sergeant:
  • 280 Answers
I asume you have a LCD tv? If that is the case then it is either the digital board or the LCD panel
Posted on Apr 26, 2008
I have a Samsung 32" LED tv model number UN32F5500FXZA. It has sound but no picture but passes the flash light test. I don't see any backlights. Any idea what the part is?
The backlights are located around the edge of screen inside the tv. Now this model is know to have LED failures. The LED strips are you backlights. The LED strips are powered by the power supply board but due to the fact that this model is know to have LED failures, I would recommend replacement of the LED strips, all of them, first. Samsung BN96 25300A Replacement LED Strips UN32F5000AF UN32F6300AF
This website currently doen't have the parts in stock for your tv however this will help you identify the parts and they even have some tutorials.
Feb 04, 2017 | Samsung Televison & Video
Sony KV-32FS13 TV no signal hdmi
Is ur tv a CRT tube type of a analouge tv u are asking?Yes than the tv don't have HDMI inputs hubs for HDMI cables connections.Only some projection tvs,all plasma,LCD and LED tvs have HDMI inputs hubs only and able give ur tv incomming signals HD 1080i for a broadcasting and HD pictures or throught a HD boxes or games devices like Xbox or Playstation 3 devices to get HD output picture for like 1080p.
Jul 12, 2012 | Sony KV-32FS13 TV
Slideshow
Check your setting son the tv. Try a factory reset of the TV. If that does not help then you might have a bad signal board.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | Sanyo 42 in. LCD TV
I have completed the setup of my Day-Timer Mwave Tx12626x Timex Electronic 7 Day Timer. I turned on my television, then plugged it from the outlet, then plugged it into the timer. The TV will not turn on...
Open following link to identify your timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
1) Don't expect the timer to turn on the TV picture.
I have my TV plugged into power strip.
Each night the power strip is off. When power strip resumes next day, the TV is READY to be turned on with the remote control. The picture does not pop up when the power strip goes on.
Same is true for timer.
Try your power strip and see if picture turns on after power strip is turned off-on.
Timer will work same as on-off switch on power strip.
2) Is the power strip interfering with timer?
Plug timer directly into wall outlet and see what happens.
Add a comment and let others know what happened.
3) Battery: Timer requires 2-hours for initial battery charge.
Battery back-up protects programs when power is off.
I don't know if battery is made for repeated on-offs if you turn off power strip each night.
These batteries are not replaceable however timer has 1 year limited warranty.
4) Plug lamp into timer and see if timer operates lamp. This will say if TV electronics are interfering with timer operation.
5) Load: This timer says it is for appliances, which implies it should be rated typical 15A 1800 watt
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 04, 2011 | Day-Timer Mwave Tx12626x Timex Electronic...
Water keeps runing throught the GMax 580
You will need to replace it with a fluidmaster.
Sep 21, 2009 | Toto Toilet Onepiece Ultramax ...
Bush BTU160DTR No Picture
Check the scart lead is fully in on the box and the tv
Sep 09, 2009 | Televison & Video
Running my tv throught my vcr but have no picture only sound
You don't say what kind of tv,model,etc. or if the tv tuner is 'solid state', push button, knob type channel changer.
If you REALLY, REALLY have to use the tv through the vcr.place the signal [antenna, cable box, cable antenna (signal) in vcr RF input.place a blank vhs tape to record, use the RCA jacks[AUDIO & VIDEO] in back of the VCR to INPUT of TV video & audio ( if you have then ) While you are recording, you will be able to see the tv program.
p.s. place the TV\VCR switch to vcr.
Dec 14, 2008 | Televison & Video
HITACHI CMPAD14D 42 in plasma it has a black strip some 3 inches wide runing near the middle of the tv from top to bottom and it some time comes on then dissapears and so on and so forth
hITACHI CMPAD14D 42 nel plasma ha una striscia nera di circa 3 centimetri runing ampio vicino al centro della tv da cima a fondo e che da qualche tempo si accende poi scompare
Oct 02, 2008 | Televison & Video
Dell W2300 LCD TV Picture Problem
Your problem is due to intermittent power in the backlighting circuit. This is usually caused by swelling of electrolytic capacitors in the power board. If you can find an honest electronics technician it is about a $40.00 fix.
Jan 03, 2008 | Dell W3201C 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
