Question about Dishwashers
I own a bosch dishwasher model SHU33AO6UC and the problem is that water comes at the bottom although the machine is off
    Problem Solver:
  • 6 Answers
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Posted on Oct 05, 2010
Bosch SHU33A-No Water coming out arms Top/Bottom.
this is suposed to ocurr for the first 3 minutes of every cycle , this step was added to dishwashers of late because everyone seems to wrinse the dishes off first ,adding a lot of driping water to bottom , so it's just pumping it out thats why it's so important to use the detgerent dispensers and not just dump it into bottom
Feb 17, 2015 | Bosch 23 in. SHU33A Built-In Dishwasher
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
Dishwasher will not fill with water although water is live to the back of the machine
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Nov 30, 2010 | Bosch Dishwashers
Water in Dishwasher Bottom
Hello Richard, Welcome to Fixya ! You've come to the right place. The problem you're experiencing unfortunately is a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's. The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic, apwagner etc. Do a search for part # 1105846 at repairclinic, you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Goof luck. Macmarkus :)
May 04, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Hi, we have a Bosch Exxcel dishwasher which mid way through a cycle a button saying Check Water came on. we turned the machine off and opened the door and found loads of water in the bottom. my husband...
Check your water level sensor. And also check to make sure that your pump is working correctly. It sounds like a couple of different things that need to be addressed. First check the water level sensor. It is a tube that is located from the back of the knob cover down to the pump. The other would be to make sure that the pump is working correctly and is not just draining water all the time. You can check these with a volt meter and make sure each is getting voltage
Feb 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Jan 09, 2008 | Bosch 24 in. SGS43C12 Classixx...
Sounds like water....dx doesnt work
2H means the machine is taking longer than 99 minutes to run a cycle. Start the cycle and wait 5 minutes, then open the door. If water doesn't look like it is spraying out the wash arms or slowly coming out the wash arms, then check to make sure the filter at the bottom is clean. If clean, then sounds like your circulation pump isn't running or impeller has came apart.
Dec 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
without a brand or model number its hard to be sure, but some types have a float cut out switch inside the washer. Its on the bottom inside and kind of resembles a plastic mushroom. The top should lift up and down easily. detergent will clog it up and keep it from moving. Just clean all the soap caked on it and move it up and down to see it it pushes a little switch underneath.
Nov 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
135 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
