Question about Exercise & Fitness
My NordicTrack EXP2000i Will not run. It does light up, but treadmill belt will not move.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
Controller is bad
Posted on Aug 13, 2010
How do I fix a NordicTrack C2050 treadmill that has abruptly stopped?
see if you can remove the motor hood and look at the drive belt. it is a little belt from the motor to the front pulley to turn the walking belt. its either broke or fell off
Oct 21, 2014 | Nordic Track Nordictrack C2050 Treadmill...
My norditrack track E3800 will not work
did you check and see if there are brushes on the motor? they may need changed
Feb 24, 2013 | NordicTrack E4000 Treadmill
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
I have a nordictrack a2250 when run on it the belt slips i need to tighten the belt
If your treadmill has had a lot of use, the belt has probably stretched and needs replacing. You can order a new one at Treadmill Parts
Nov 07, 2010 | Nordic Track NordicTrack Treadmill, A2550
Belt doesnt work when I hit the start button
Sounds like the motor control board. Everything will work properly but belt want move. Clock will even start to count down.
Nov 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Oct 29, 2009 | Nordic Track NordicTrack Treadmill, A2550
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
105 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
