Question about Canon DR-2580C Path-Through Scanner
We have a Cannon DR2580C, it has been working well for several years. The image is now starting to fade on the right side, so we no longer have the entire image
    President:
  • 2,571 Answers
I would try and clean both sides of the glass.
If this does not help, probably time to either replace or look for a replacement lamp
Posted on Aug 04, 2010
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
The clock has stoped working on my cannon chesterfield cooker, why!!
i have the same cooker (in brown colour) and is just 3 years old. The clock was coloured green and over the last 6 months or so has gradually faded to no illumination at all. Then it started to buzz very lightly when the mains was switched on to ignite the gas. In August 2011 phoned Cannon Indesit repair line on 08448 224 224 and agreed to pay £104.99 for call out and labour to fix. The parts are covered for 5 years so no charge for the clock. Engineer took 22 minutes to replace the clock which is now a deep yellow colour and much easier to see in the daytime.
Sep 03, 2011 | Cannon Chesterfield C60G Kitchen Range
After several years use without accidents or damage, cannot focus to one image any longer and left eye will not focus to clear any longer. They are Barska, 8x42 reverse porro prism.
I fear these have suffered damage without your knowledge. The collimation has gone bad, hence the two images instead of one. As the left side doesn't focus properly, I would guess that one of the prisms in that side has shifted position, which would account for both defects. This can be fixed by a skilled and knowledgable person, or made worse by someone who does not know what they are doing, but in the end, it may be too expensive to have them put right by an expert, as very good binoculars are available quite cheaply today.
Nov 16, 2010 | Barska Optics Optics
Right hand side of print outs are faded. The machine is a cannon mf 4150
Most of the time when you have faded copies it is due to the processing section of the copier. An number of things can cause this:
  1. Dirty optics
  2. Copier not level from to back
  3. Dirty charge or transfer corona
  4. Bad drum unit
  5. Contaminated developer section
  6. Dirty Laser unit
  7. or Worn fuser unit
These should be taken care of by your local Authorized dealer.
Sep 17, 2009 | Office Equipment & Supplies
I print borderless several times & found white border both side
This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
New Computer; Windows VISTA; Scanner Canon DR2580C drive loaded from Internet. Capture Perfect 3.046 loaded from INternet. Att4empting to scan a document produces a info box with the words "Scanner is...
go to device manager and make sure that the device is working properly because if the driver for the scanner may be missing and you will have to acquire it to use your scanner. if you need anything else please feel free to leave a comment.
please rate me. thank you.
May 28, 2008 | Computers & Internet
I have VISTA, A DR2580C and Capture Perfect 3. When I select Capture 3 a message comes up "Scanner is not found check cable" I previously installed Capture Perfect 3 then upgraded it using the Cannon...
Hey...dont get me wrong...we all make mistakes...am sorry again for that mistake...
if you are intrested try this way again...
> goto device manager > right click that is yellow > select uninstall driver > and repeat it to the other named something scanner
and > do again the installation again (what i told you in chat) for all yellow flags > restart windows >
ask me any prob at my profile? Roshan89...
May 21, 2008 | Canon Office Equipment & Supplies
Faded colors
moniter colours changed what prabulem
Nov 22, 2007 | Samsung SyncMaster 793MB 17" CRT Monitor
Faded Picture
I would have to say it does sound like the CRT is reaching its end. The thing that points this out that the picture gradually gets a little bit better as it warms up. It most likely isn't worth the cost to fix it.
May 07, 2007 | JVC AV-27230 27" TV
Canon DR-2580C Path-Through Scanner Logo
185 people viewed this question
old marine
old marine
