Question about Amcor AMC12000 Portable Air Conditioner
I HAVE A AMCOR 13000E PORTABLE AIR CONDITIONER THAT KEEPS SHUTTING DOWN AFTER A FEW HOURS ITS NOT FILLED WITH WATER.I'M NOT SURE IF ITS A TIMER PROBLEM.I DON'T HAVE THE OWNERS MANUAL. THX-JOE
  • Dave Johnson
    Dave Johnson Jun 19, 2017
    Hi, Try washing the filter
I have user manual- giznwiz@btinternet.com
Posted on Nov 24, 2010
The condensation tank is filling and causing the unit to shut down every two hours. The internal pump that sprays water (from the collection tank to the exhaust vent) is apparently not working. Will this...
Shut it down until you get the drain working again. That spray is what helps save you a few buck on your Cooling bill. Let that excess water get in your house then maybe kiss your pocket book goodbye
Sep 10, 2013 | Amcor PLM-14000E Portable Air Conditioner
My portable ac unit keeps filling with water and shutting off. Why is it shutting down once an hour and flashing p2?
if it's a window unit it needs to sit at an angle so the water can drain out of the back. Make sure the drain is unclogged
Jul 16, 2012 | Heating & Cooling
When i turn it on it shuts off and the power button flashes red
Sounds like the condensation pan is full and the float switch is shutting the unit down. I just encountered this issue, there is a small pump that usually prevents the pan from filling up by pumping the condensate over the condensor and evaporating it, either the pump has failed or the humidity is too high and it can't keep up.
May 24, 2012 | Amcor ALTL-12000E Portable Air Conditioner
Water collects much more rapidly & unit shuts off
the tank will fill more rapidily when the humidity level is high,empty the tank and keep all windows closed and you should notice it slowing down over the next couple of days
Jul 23, 2011 | Amcor PCM 10000EH Portable Air Conditioner
My amcor air conditioner is leaking water all over the floor. I drain it and it will only last less then 24 hours till it turns off, leaks all over an needs to be drained. Help!
I figured out the problem. My Amcor portable started leaking after the fill light came on for the first time in years. After doing some research I saw that it uses the water to cool some other part of the system to evaporate out the exhaust. So I took the ******* apart and messed with things. Finally I started pouring water into different trays and noticed it would not drain down from the top tray even when running. So I removed the top part and found the drain hole. Blasted that sum ***** with some compressed air and WAMMO it works again.
-madmanmarz
Jul 06, 2011 | Amcor PLM-14000E Portable Air Conditioner
Amcor 10,000BTU set at 64 degrees - - temperature of air coming out of unit is 72 degrees. In one and half hour set at 64 degrees the room temp only went from 90 degrees to 84 degrees. Recommendations?...
I am not sure, i have a similiar unit that is brand new, seems like a faulty mechanism from the maker, it starts cold for about 2-3 minutes and then shuts down condenser and blows hot air repeating this cycle. I don't believe it ias a recharge, just a faulty machine
Jul 15, 2010 | Amcor PLM-14000E Portable Air Conditioner
Keeps filling with water and shutting off.
Air conditioners remove moisture from the air like a dehumidifier does. With portable units it is captured in a removable container and when full will turn the unit off so it won't overflow onto the floor. There should be option for a hose to attach to the bucket which could be run to a drain so you won't have to keep emptying the bucket. Just remember the a/c unit needs to be higher than the drain.
Aug 21, 2009 | Amana Portable Air Conditioner
Amcor ALD12000E portable air conditioner shuts down every hour
Is it leaking or shutting off on the overfill?
If it is leaking you have a stopped up drain inside the unit.
jim
Jul 27, 2009 | Amcor ALD12000E Portable Air Conditioner
Amcor AMC12000 Portable Air Conditioner Logo
401 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
