Hi, My Dell Inspirion 1546 will power up, give me the welcome screen and then nothing but a blank screen with a flashing cursor. I've seen this problem show up online over a dozen times with no resolution. My warranty just expired 2 months ago. Any suggestions? Thanks!
  • 11,800 Answers
This happens because the BIOS can't find a boot loader. This happens because either the disk is severely corrupted and the only way to fix that is to reinstall, or that the hard disk itself has been damaged and you must replace it and reinstall.
To find which just go into the BIOS and see if the hard disk is correctly identified. If it is then maybe the disk isn't to blame (or the damage isn't terminal yet). In that case reinstall and see what's happening; if you start getting errors soon after the install then the disk is damaged and must be replaced. Use what life it still has to recover your files.
Posted on Aug 04, 2010
  • 2 more comments
  • Shantelle Aug 05, 2010
    Having trouble getting into BIOS. Can you walk thru?
  • Azrael SRL Aug 05, 2010
    To access the BIOS all you have to do is to press the F2 key when the laptop starts.
    yes did that. but nothing happens afterward. I've even hit the Load Default key.
    Press it and keep it pressed continuously till you get into the BIOS. If this doesn't work then the BIOS is corrupted and you must take it to a shop for the BIOS to be updated offline.
HP S230 monitor won't connect to my Dell Inspirion 15 laptop via DP to HDMI cable
Hi Msdco1, 1st try fixing your laptop..... The link below is a YouTube video showing 3 ways on how to fix your laptop, Also there's videos down the right side of the link that may help as well, I hope this helped....CHEERS..
ALL LAPTOPS DISPLAY NOT COMING ON BLACK or BLANK SCREEN DIM DISPLAY
May 10, 2016 | Dell Inspirion 15
Dell inspirion 2200 password lock out service tag: FG1XX81
If you mean the windows password screen, software is available to break in. Quite expensive though.
Mar 22, 2014 | Dell Inspiron 2200 Notebook
Vostro 1500 screen blank except for flashing cursor
The good news is that your laptop powers on and you have a display. The bad news is that you laptop is trying to boot up from an OS (operating system software) like XP, Vista, or Win 7. Ether your software is corrupted or you have a problem with the hard drive or hard drive controller.
Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Another more intense diagnostic program is located on a Dell CD that you should have received with your laptop. Look for one that has "Diagnostics and utilities" listed under the "Contents". You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the "One time boot menu". Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the "Run the 32 Bit Dell Diagnostics".
If diagnostics pass then your software is corrupted and needs to be reinstalled.
Mar 03, 2013 | Dell Vostro 1500 Notebook
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
Jul 01, 2012 | Dell Precision Workstation 470 (204816690)...
My laptop will not turn on. It begins to start normally with the Windows screen, but goes black with just the cursor showing, then goes into a kind of sleep mode with the cursor grayed out. When I plug...
Put the Windows disk in and repair the drivers. Should be easy follow on screen instructions, if not use the DELL OEM disk to start and do repair. I have a Dell Inspirion it did this b/c of a virus. I just did a repair WIN7 and all is good now.
Jul 10, 2011 | Dell Studio 17 Laptop
Dell Inspirion 530 start up one beep dell logo to black screen with cursor. Ran repair w disk nothing happened what are my options will reinstalling vista fix this is there a remedy without losing all data...
Normally this means the memory cards are not seated properly in the motherboard. Pull them out flip the white plastics retainers on the sides down and reinseert.
Jun 14, 2011 | Dell Inspiron 530s Desktop Computer
Hi, i have a problem with my Dell Inspirion 6400, after replacing Motherboard laptop won't boot up, after pressing power button, all 3 lights comes up (caps, num and scrl lock) and than back off, power...
I would hook up an external monitor to see if the laptop is working. If it is working fine then you must have a connection problem where the LCD plugs into the motherboard. I am willing to bet it is the LCD cable mot seated correctly. If it does not work on an external monitor try switching the memory chips one at a time if you have 2. Everything you mention indicates it is booting but no video. Good Luck Phil
Feb 21, 2010 | Dell Inspiron 6400 Notebook
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
