Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I am unable to print- the paper moves thru the printer but is blank. It sounds normal at first, but the sound stops after about 4 seconds.
  • 4,323 Answers
Hi
Please check if the cartridges are not empty. If the are filled then try reseating them . Try a ower reset by turning off the printer, turning it on and then unplugging it without turning it off. Plug in the printer after 10 seconds and check if you are able to print. Make sure that there are no paper jams or bits of paper stuck around the cartridges. This issue can also be due to a faulty purge unit.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 04, 2010
Printer sounds like it is printing but paper is blank when done
gabriel, have you tried to 1. clean and 2 allignment of cartridges using the tool function.?
Mar 24, 2014 | HP F4480 All-In-One Printer
Printer functions fine, but nothing is printed on paper
are these new carts? or have they been sitting around long before you installed them?
Print sounds but blank paper
Try a few print head deep cleanings if that does not help then you could try soaking the print head in a shallow plate of hot distilled water. Soak the tip of the print head only in no more than 1/8th to 1/4 inch of water.OR
Still Having Canon Printer Problems Then follow Us On: Canon Printer Support
Jan 29, 2014 | Canon PRINTER CANON IPF8000S PRINTER...
Sounds like it's printing, ejects the paper and it is blank. Help!!
Try the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on, re-insert both cartridges.
  6. Close the printer.
  7. Load some paper in the feeder.
  8. Try to print again to verify that the problem is fixed.
Let me know how it goes.
Dec 05, 2011 | Lexmark X2500 All-In-One Printer
I have a HP Office Jet Pro 8500 A909a My wife sent
1) Turn the printer OFF.
2) Unplug the printer's AC adapter fro the rear of the printer.
3) Unplug the AC adapter cord from the wall outlet.
4) Wait a FULL 10 minutes minimum...While waiting, go to step 5.
5) Remove the rear access door. Reach inside and rotate the rubber feed rollers on the shaft with your thumbs until they stop/click.
6) Use a can of compressed air and blow out the entire access interior.
7) Use a magnifying glass and a flashlight to to inspect for bits of torn paper or other foreign object that may still be locking the feed sensor in the feed position.
8) Try to locate the sensor and see if it is stuck. It should be spring-loaded and easy to move with a narrow screwdriver or pick.
9) Put the access door back into place (make sure it is completely closed/seated)
10) Plug the AC/power cables back in, turn the power button ON and test for a normal print process.
Dec 03, 2011 | Computers & Internet
Canon BJC 4400 won't put ink on the paper
You need a new printhead, BC-21E, they wear out and plug with ink and the only repair is to replace the printhead.
Sep 16, 2009 | Canon BJC 4400 InkJet Printer
Paper passes thru printer and it sounds like its printing but each page is blank
The print head on your cartridge is likely clogged. Test with another printer cartridge.
Post a comment if this doesn't help and I'll get back to you :)
Jul 01, 2009 | HP Deskjet 6980 InkJet Photo Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Paper is printing but top edge of paper is creased and torn
It sounds like your maintenance kit is defective.
The excess oil leads me to believe that.
Jun 04, 2008 | Xerox Phaser 8200 Laser Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
24 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
