Question about Evolis Pebble Color Card Printer
My Evolis Pebble 3 ink ribbon breaks after I print 2 cards.
    New Friend:
  • 54 Answers
First clean Rollers and print head . Check if you have increased luminosity and contrast too much in printer Graphic properties. If this doesn't solves your problem increase x offset little bit using Px;+ command in Dialog with printer
Posted on Apr 13, 2011
Hello, We have a problem with our EVOLIS PEBBLE
reload the ribbon make sure you load correctly and set the correct type of ribbon on the driver make this and reply to me
Aug 24, 2011 | Evolis Pebble Color Card Printer
Evolis Pebble 4 with a gold monochrome ribbon. Printing on pre printed blank cards. The print is not complete, almost as if there is not enough pressure on the card as it is printed. All the letters are...
Make sure you have selected gold ribbon in printer graphic properties.
Also you can try changing luminosity and treatment options in graphics under Advanced setting.
Check for print on a white card also as problem may be due to card surface also .
You should cklean print head also at once.
Oct 04, 2010 | Evolis PEBBLE 4 Led Card Printer
I have problem with my Evolis Peb3le. For a long time (+- 3 years) ago, i use ribbon with S/N: RP011IPS, and it's running good. But, now, i can't get that ribbon with S/N: RP011IPS, YMCKO, i just only...
Just check for the ribbon type setting in driver . It may be required to be corrected . Also try downloading new firmware from Evolis site for Pebble3.
Sep 19, 2010 | Evolis Pebble Color Card Printer
My ink ribbon breaks after it prints 2 cards. I have an Evolis Pebble 3.
Clean all transport rollers . check for X offset by giving Rx command in Properties/Tools/dialoge with printers. Increase offset little bit using Px command
Aug 04, 2010 | Evolis Pebble Color Card Printer
Fading image...
1.Check for proper driver on evolis site.
2.Check whether both side printing is selected in driver
3.Check for Varnish sensitivity setting in Graphics setting it should be default.
4.Read the ribbon type with Rr command.
Feb 23, 2010 | Evolis Pebble 3 ID Card Printer Package...
My Evolis Pebble 3 says feeder error but there is not. It won't pick up a card when you try to print but when you press the push button it feeds out a card without printing. It will alos not print a test...
You must take following approach
1. There is a lever at feeder for thickness adjustment . Check it for proper thickness.
2. There is a hanging lever which acts as a card presence detector just where you place cards check if it is stuck and try to clean sensors aside it by blowing air .
3.Check if feeder motor is working by giving Mf;+ command
4.Check for proper ribbon setting.
5. Try downloading firmware which is available as an exe file for different models on Evolis site.
6. diagnostic software is also available on site.
7. You can also do self adjustment to adjust sensors.
Aug 16, 2009 | Evolis Pebble 3 ID Card Printer Package...
Evolis Pebble 3 printer: the varnish is being put on as black
Check if ribbon type is proper.
Do self adjustment at once.
Clean optical sensors emitting blue light just below you install ribbon in printer
Jun 28, 2009 | Evolis Pebble 3 ID Card Printer Package...
Evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Jul 04, 2008 | Evolis Pebble 3 ID Card Printer Package...
Evolis Pebble Color Card Printer Logo
252 people viewed this question
Top Evolis Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
