Question about Boating
How to remove a inboard -outboard boat motor - Boating
3 Suggested Answers
  • 5687 Answers
SOURCE: looking for location of impeller on a inboard
If it has a OMC or Volvo most are in the top of the outdrive. If your motor looks like a car engine it can be if the front just like a car. This website claims they have online access to repair manuals so I would look there first. Go to other websites and look for impellers with the brand of motor, like Volvo impellers, Mercruiser impellers and some of those sites have excellent parts diagrams.
Posted on Apr 28, 2009
  • 53 Answers
SOURCE: want to replace the trim/tilt motors on my 1995
no. a unmodified transom bracket may need to be moved not removed. Since the tilt motor is out you will need to manually lift the engine. you can see the picture diagram at www.yamaha-motor.com. click on outboard motors,parts and service, view parts catalog. find your year make and model by following steps listed at top. select power trim and tilt assembly. in the picture you will see the location of the Manuel release valve on the starboard side. turn the Manuel release valve then lift the engine. tie it up or use a stand to keep it up,do not use the tilt lock. with the engine in full tilt position, you can see the motor. some brackets are modified were you can remove the motor without moving the transom bracket. If unmodified you'll need to follow these steps. (1) lower the engine back down.the steering arm needs to be removed from the steering cable and swung forward. do not remove steering arm from engine. on the starboard side of the engine you will see the steering cable going into the steering cable tube. (2)a 1 1/6 nut secures the cable to that tube remove it and slide cable out do not remove it.(3) lift engine again and secure it. your about to remove the motor mount bolt so make sure you secure the motor completely (4)remove upper and lower transom to bracket bolts remove bolts on the port side only.(5) you will see three bolt that go through the transom bracket to the trim and tilt assembly. remove them.(6) if all bolts are removed you will be able to slide the port transom bracket to the left out of the way(7) remove tilt/trim motor.
Posted on Nov 03, 2009
Have evinrude outboard serial number 1591802140. What is model number and year?
Hey Jan,
The model number/serial number should be on plate attached to the engine mount...You need the model number to determine year.
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
Jun 25, 2017 | Boating
Motor backfires, does not start, just had the motor redone, seems like timing is out although it has electronic and not points
what engine do you have , inboard or outboard ?
inboard , tdc number one cyl and check lines up with number one pin on the distributor cap and the timing mark aligns with housing !? if out the readjust !
outboard , tdc number one cyl and check flywheel marks line up with casing !?
remove flywheel and check keyway not broken or missing !
Mar 27, 2015 | Boating
How to winterize an inboard/outboard boat motor
Flush the motor with fresh water, drain and refill drive gear with fresh oil , the same with the motor, remove spark plugs inject 10 ml of engine oil into each cylinder, turn engine over by hand so cylinder walls are coated, refit plugs. I then like to spray every thing WD 40. Remove the battery if you have a trickle charger connect it.
Oct 20, 2014 | Boating
I just got a new boat this summer and I live in Seattle, where I will use my boat year round. I have been told that I should winterize the motor so it doesn't freeze in the lower temperatures. What should...
I used to live in the Chicago area. We definitely had winter (below zero).I went thru extensive winterization for the inboards and stern drives. I fogged outboards and put Sta-bil in the gas. I also ran the gas out of the carbs or drained them but the boats would sit unused for 6 months. Does the boat stay in the water? If on a trailer, lower the motor so it is in the run (trim down) and the water will run out. If you tilt it up after this for storage, cover the gear case as it can fill with rain water and freeze.
Jul 24, 2014 | Light Outboard Motor Boat Bass Fishing...
What are the types of engines for boats?
The main types of engines when it comes to boats are: steam engine, gas turbine, diesel engine, steam turbine, and gasoline engine.
Jan 10, 2013 | Boating
I dont have a break down of the parts for my motor and i dont know where the water pump is at
water pumps are in the lower unit . whether it is inboard/outboard or outboard. straight inboards have a diffferent kind usually .
Mar 21, 2010 | Boating
Boating Logo
527 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
