Question about Ovens
Whirlpool Electric Convection Oven coding E6 F2 - we know this is common and we know it's likely the connection to the motherboard - our question is how do I get the motherboard out so we can have it fixed? What is the process for removing this board from the oven? Should we be able to removed the panel from the front of the Oven, or, do we have to take the entire double oven out from it's wall location to gain access to this board? Thank you. Janice
    Brigadier General:
  • 3,513 Answers
Hi
This code is in reference to the control sector. There seems to be a malfunction that has been detected within the touch/key pad assembly. Use the procedure to isolate the damage.
Check keypad connector for firm connection (keypad connects to control board).
Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 04, 2010
  • janicemfcc Aug 04, 2010
    Hi thank you for responding. We know that the problem is within the touch/key pad assembly and it may be nothing more than the keypad connector.....our question is how do we get to the keyboard connector to check it? How do we remove the touch/keypad assembly to get to the connector so we can check it? thank you. Janice
Whirlpool electric double wall oven error code E2F6
Good Morning!
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Mar 22, 2017 | Whirlpool Ovens
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
F2 error code
F2 E6 says this:
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
Aug 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool code E6 F2
Hello ssuebe51
Welcome
Turn the power off to the oven.
Check the connection from the key pad to the clock.
If the connection is good then put back together.
Turn power back on and press the cancel button.
If the error code returns after 60 seconds then the keypad will have to be replaced.
Thank you huuum
Please remember to leave a rating
Sep 19, 2008 | Whirlpool RBD305PD Electric Double Oven
Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
15 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
