Question about KitchenAid KTRP22EK Top Freezer Refrigerator
Where can i find the defrost cycle in my freezer? The coils were frozen up so I have defrost everything with a hair dryer. The fan is working but I want to check the defroster.
  • 1,606 Answers
On your model , the defrost timer is located just behind the thermostat control knob on that control panel . A small 1/2 " diameter hole is the timer set hole .
Posted on Aug 04, 2010
    Sergeant:
  • 216 Answers
This timer is generally located in the under the fridge in the front or back. It's generally looks link a small square box about 3 inches square with a single round slotted dial. When you locate the timer using a flat head screwdriver simply turn the dial until you hear the compressor turn off a click. If the fridge is not running you can open the door long enough to warm it up and get the compressor started then turn the switch to make sure you have the defrost timer in the defrost mode. I would also suggest that you check the fridge hourly and make sure that it has started running again after a few hours. If you have a faulty switch this could keep the fridge from starting again. If the switch is faulty and the fridge fails to start by itself then simply rotate the timer until the fridge starts.
Also if your fridge is opened a lot or you live in a high humidity area this too can cause excesive icing.
www.appliance411.com/faq/howdefrostworks.shtml This link will give you a better understanding of fridge operations.
Top half of upright freezer is warm
Hello Karen;
My name is Peter. I am a retired field service refrigeration technician.
The top half of your freezer is warm because your cooling (evaporator) coil is on the bottom.
With your unit there are generally two cooling problems:
1.) Frozen Drain - You freezer will go through a defrost cycle every 8-10 hours. When this occurs, everything shuts down with the exception of your lights. Your defrost heater turns on for about 20-30 minutes, defrost you cooling coil and them turns your unit back on.
Most common, is that you have a frozen drain. If you have a frozen drain, when your unit goes through the defrost cycle, if your drain is plugged then the condensate builds up on your cooling coil and restricts the air flow. Use a hair dryer and melt the ice.
2.) Freezer fan motor is bad - Your freezer fan motor may be bad. This is easily replaced.
Ok, Lets get it done. I have faith in you.
a.) Unplug your unit.
b.) With a screw driver remove the 6 screws holding the bottom cover. You control may be in the way.
c.) I know you can do this. Remove the back cover. Is you cooling coil blocked with Ice? Defrost with a hair dryer. Do not use metal tools, you may damage the cooling coil.
b.) After defrost, Is you cooling fan running. You can do this as well. There are only two contacts to remove and a ground wire. If it is not running purchase a new one.
I have faith in you Karen. Call me and I will walk you through this.
443-306-1362, Glen Burnie, Maryland, USA
Dec 29, 2014 | Freezers
Water on top shelf of refrigerator
The drain in the freezer compartment is probably frozen and the resultant overflow from the defrost cycle is dripping into the refrigerator. A total manual defrost of the freezer will usually do the trick. Remove all the frozen product and place in coolers and cover them with a blanket or two. Unplug the unit and prop a fan on a stool to where it'll blow into the freezer for a couple hours. Then assist the defrosting by use of a hair dryer on the high setting all across the bottom of the freezer compartment. Monitor the temperature on the plastic with your other hand so overheating of the plastic does not happen.
Once you use the hair dryer for 15 - 20 minutes, find the plastic tube that comes out the rear of the box or possibly where it drips UNDER the refrigerator into he drain pan. Slip it out and blow backwards up through it to ensure there is no blockage of sludge or ice. If it is still blocked, go back to the hair dryer again. A hint: while you are near the drain pan, inspect the condition of the condensor coil to see if a good cleaning is required. They are usually impacted with dust, lint and other stuff inhibiting their ability to reject heat.
Aug 25, 2014 | Frigidaire Refrigerators
Fridge had a lot of frost at the back (top fridge/lower freezer), turned it down and it defrosted, however, the freezer doesn't seem to be working properly either. Defrosted it all last night and this am...
It sounds as if the freezer coils and vent stack are frozen solid. This usually requires
removing the back panel in the freezer compartment and defrosting carefully with
a hair dryer. (If this becomes frozen it blocks off the fan/vent that feeds cold air down to
the fresh food compartment) Make sure to unplug unit before servicing as you will need
to unplug the fan to remove the back panel.
While doing this check the defrost termination thermostat (a small device attached to
the tube with two wires coming out of it). The black plastic ones sometimes come apart
and fail.
Once defrosted put everything back together and test.
Hope this helps.
Mar 15, 2011 | Refrigerators
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
Refridgerator side not getting cold model gss201epaww
make sure the damper vent door located between the freezer and refrige compartments is opening and letting in cold air from the freezer,if they ice up they can stick shut and not allow air flow,this door is behind a plastic grille an a hair dryer works great to defrost them
Apr 30, 2010 | Refrigerators
Hi, I have double door refrigerator. The fridge section is not working at all however the freezer section is giving excessive cooling
If the freezer is cold then it is having trouble circulating air, first make sure the evaporator fan in the freezer is on.  If it is not check for power, if you have power replace the fan.  If not it is probably the defrost thermostat.  If the fan is on then more than likely your evaporator coil is frozen over.  The fridge goes through a defrost cycle every 8-12 hours depending on the model.  If this is the case then get a hair dryer and melt all of the ice, this will keep everything working until you can get it fixed.  It is either the defrost thermostat, the defrost timer, or the defrost heater.  Check the heater for continuity, if that is good, check the defrost timer which should be located near the heater for continuity, if that is good replace the defrost timer.  Do not put the freezer on the coldest setting.  The freezer temp is really an air balance, and when you put it on the coldest setting it shuts off all airflow to the fridge.
Nov 07, 2009 | Washing Machines
The firdge is pluged in everything is on. temp. is at the coldest and the fridge is warm inside
Nov 07, 2009 | Kenmore Refrigerators
Our produce are spoiling within 2 to 3 days. Do
First I need you to unplug the refrigerator. Remove the rear panel in the back of the freezer and tell me if the coils are clear, frozen or blocked with ice. Make sure both fans were working before unplugging. Below the bottom and the fan inside the freezer. This will let me know if there is a problem with your defrost system. If frozen over use a hair dryer to defrost coils and let me know. We will need to check the defrost heater and defrost thermostat. Let me know when you are ready or if this is helpful, Thanks Sea Breeze
Jul 14, 2009 | Amana Easy Reach Plus ABL2227FES Stainless...
Fridge and freezer not cold and frozen up
Can you remove the back panel inside the freezer and defrost the coils. Use a shop vac with the hose in the blow position instead of the vacuum position. And blow on the coils to defrost quickly. Hair dryers work also but prolonged use will burn up hair dryers. Now turn back on and see if the inside the freezer fan works. It should be running to keep the coils from freezing up. Also could be defrost timer. But this will be enough to get you going. Let me know how it goes. ken
Jan 12, 2009 | Samsung RS2630SH Side by Side Refrigerator
Water inside bottom of freezer after defrost cycle
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KTRP22EK Top Freezer Refrigerator Logo
213 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
