Question about Home
I flush my toilet and it wont flush most of the time and it will just have water swirl around the bowl. The water never reaches the top of the bowl. What seems to be the problem?
  • 76 Answers
It sounds like you have a small clog. try plunging the toilet, but if that doesn't work try liquid plumber or a snake
Posted on Aug 06, 2010
Toilet not flushing properly
Check the fill valve for any obstructions, or the diaphragm under the top cover. where the small hole attaches to the top of the fill valve. Why was it removed? If due to blockage the blockage may still be inside the bowl trap.
Aug 30, 2014 | Kohler Home
50 year old American Standard toilet . Bowl fills up ,makes noises like it's pluged & then flushes
You have a blockage in the trap as the water goes out . What happens is that there is so much pressure with the water building up in the tank,, that it finally pushes the water out. Also check the vent above the toilet which is located on the roof. It must be free of debris to allow the pressure to stay equal and not a vacuum.
Feb 18, 2013 | American Standard Traditional Champion4...
Toilet fills with water then slowly goes down
you have a blockage maybe outside in your shores
Oct 16, 2012 | Home
Water splashes out of toilet fbowel when flushed
Try lowering the float level. This will reduce the amount of water in the cistern and lower the pressure on the flapper so when you flush the water will not flow as fast into the bowl.
May 27, 2012 | Home
American standard toilet doesnt always flush, water swirls around
There is a clog in the line. A plunger usually solves this problem, but you have to use a toilet plunger. Your local hardware store will give you the right tool ($13). If the plunger doesn't work, you need a toilet auger (also called a closet auger), which you can buy for less than $20.
Apr 26, 2012 | American Standard Home
American Standard Toilet does not flush except on rare occasions. Most of the time the water just swirls around but doesn't flush out. Waste is left in the toilet but the water does not back up in the bowl...
I would suspect some sort of air lock in the pipe, or just a partial blockage which is slowing the water flow.
You may be able to clear it using a rubber plunger. You need a plunger that has a metal or hard plastic disk fitted above the rubber cup (to prevent the cup turning inside out).
If you have an ordinary plunger without the disk you could probably make one to fit it - perhaps the bottom cut out of a plastic drinks bottle and a hose clip to hold it in place.
You will need to work the plunger quite vigorously up and down in the toilet bowl to force a pulse of water through the system.
Pouring a large bucket full of water down the toilet after plunging may have more impact than just normal flushing. It will also refill the trap.
Feb 25, 2011 | American Standard Colony 2388.012.222...
My mothers toilet will not flush, its like theres no suction, when flushed the water in the bowl goes down very slowly but not all the way down to the hole and when it does its very slow weak suction. I...
Try getting a bucket full of water and dumping it pretty rapidly into the toilet bowl. This is essentially what happens when the toilet is flushed normally, but it removes the variable of how the water is being delivered from the tank to the bowl. It should swirl and go charging down the drain, quickly leaving the bowl with very little water. If it does not act that way, then problem is definitely that the drain is obstructed. When you snaked it, you probably used a fairly short snake (about 10 feet?). Try a plunger - use a good one not the kind designed for sinks. Flush multiple times and get vigorous with it. If that doesn't clear it you will have to remove the toilet and use a much larger and longer snake (50 ft or more). good luck, Al K
Dec 31, 2010 | Home
Toilet bowl doesn't hold water but tank is full
The bowl is filled up with the little hose inside the tank, it locks inside of the overflow drain. And runs water in there as it flushes to swirl the water and fill the bowl. Water seeks it's own level, and the level in the bowl is at the top of the trap. It has to hold water, unless it isn't filling or it is leaking. Check out the filler and hope the bowl doesn't have a crack in it. Hope this helps.
May 03, 2010 | American Standard Home
Tiolet won't flush = water swirls but won't fully flush.
Mine does this too, from time to time. I've found that it usually means there's a plug somewhere down the line that you can't reach with a coathanger. Since I keep forgetting to buy a plunger, I use a johnny mop to vigorously poke in and out of the bottom hole until most of the water in the bowl is gone. After doing that, a couple flushes usually clears the line.
If that doesn't work, you'll probably need to use a snake on it.
Mar 17, 2009 | Home
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
Dec 28, 2008 | Jacuzzi Bath Era BK37 959 White toilet...
Home Logo
96 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
