Question about Sharper Image SI830 Ionic Breeze Pro Series Air Purifier w/ UV Light Air Purifier
Need a manual for si830 purifier - Sharper Image SI830 Ionic Breeze Pro Series Air Purifier w/ UV Light Air Purifier
I need an owner's manual for Honeywell Air Purifier HHT-082-TGT and cannot find it on the Honeywell Instruction Manual website
Hello, this is Ava with Think Crucial.
You may find you online instructional manual for your Honeywell model by clicking the link below.
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/hht080hht100.html
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 12, 2015 | Honeywell Pet Cleanair Air Purifier...
I need a manual for a hunter 30250 model air purifier
Hi and welcome to FixYa, I am Kelly.
This should be your 8 page users manual:
http://www.appliancefactoryparts.com/content/pdfs/116668.pdf
If this answers your question would you at least say the problem is solved? Otherwise you will keep getting email notifications of where to find the manual.
Thanks for choosing FixYa,
Kelly
Jan 16, 2011 | Hunter 30250 Air Purifier
Unit will not go on.
Without actually seeing the unit I can tell you the power cord that you plug into the wall, the first thing that happens is the hot a/c wire (black) solders to a fuse at the bottom of the unit into a pc board. Then on the load side of the fuse a (red) wire travels up to the top of the unit and is series through 2 micro switches. The first switch is to monitor the collector grid that is the part you pull in on the lever at the handle to remove and clean about every 2 weeks. Then from that switch still at the top of the unit the (red) wire travels around to the back of the unit and that switch monitors the rear back cover to be in place. From there it goes back down to the bottom of the unit into the circuit control board. Enough said about the power lead. I am sorry if I am a little technical, but that is the only way I know how to help you. I have been an electrician/elect tech for over 37 years. Now with all that being mentioned remember I told you about the soldered in fuse, well its been my experience over the years that if the manufacturer wanted you to change that fuse easy it would not have been soldered. What I am saying is that if it is blown, it is well beyond the scope of the end user to repair. Some things to look for is back cover and grid collector seated properly. Then you could check switches for broken wiring or maybe a switch is misaligned. This requires some disassembly if your not sure of yourself there three levers you can choose from when attacking this unit A,B,&C. It is best to use lever b and do not attempt tearing it down if you do not trust your working on it. I hope this might help you this the best i can do without tearing into unit myself.
Dec 16, 2010 | Sharper Image SI830 Ionic Breeze Pro...
Need manual for Filter Queen 360 Air Purifier
I'm going to go out on a limb and guess you want the Defender model and not the Majestic model. I believe the latter is a vacuum. Here's a link to the Defender 360 manual. Best of luck.
http://www.filterqueen.com/pdf/defender.pdf
May 27, 2010 | Filter Queen Defender Air Purifier
Check collector cell
sounds like you need to clean the cell
Jul 26, 2009 | Oreck Professional Air Purifier Air...
Air Purifiers Logo
90 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
