Question about Kenmore Washing Machines
My Kenmore Super Capacity Plus Washer, Model No. 110.27892790 will not fill with the needed amount of water for most specifically the Large Load setting. Will a new Water Level Switch solve this problem? thanks for your help.
catriver
  • 878 Answers
SOURCE: Washing machine Kenmore 3.2 cu ft Super capacity plus top loader
fabi, if Im reading you right the machine fills with water and just sits there. Can you hear the motor running when it should be agitating? If so you might have a broken coupler. If the machine is quiet and just sits there, it could be the pressure switch. The first picture shows the pressure switch with the rubber hose and purple wire going to it (far left). There is no model number posted but this is a top loading Kenmore, should be close. Take the rubber tubing off the switch and blow into the switch with another piece of tubing. Does it start agitating? If so, there's your problem. If you do hear the motor running and it's not agitating it may be the motor coupler. If you need more assist...email me at catriver1@gmail.com Catriver..post back.
Posted on Feb 05, 2007
  • 60 Answers
SOURCE: Clothes washer overflows
take the hose off at the pressure switch and blow through it if there are no restrictions then you have a faulty pressure switch let me know how you make out
Posted on Sep 12, 2007
Jimster
  • 240 Answers
SOURCE: WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Posted on Feb 15, 2008
  • 185 Answers
SOURCE: washing machine water capacity for each setting
it should be in your use and care guide
Posted on Mar 27, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Washer Problem
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place.
Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. NOTE: You DO NOT have to drain the tub to repair the lid switch.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions or need help locating the correct part, please let me know by posting comments.
Posted on Apr 08, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Model wdss4120aww GE Washer is leaking
If it's leaking during the agitation cycle, and only in 'large' and 'super' water levels, then that's just the way the washer is designed. I got rid of that piece of junk.
Mar 03, 2013 | GE WBSR3140D Top Load Washer
I have a Kenmore Series 70 Super Capacity washer. The model number is 110.23712 200 (which doesn't seem to be a valid number when I do an internet search, but is the number on the plate on the unit). I...
Getting Sears parts 110.23712200
I will tell you what happened to me. One day my water valve quit. On that veryday my sister in law paid her weekly visit to wash her and my BIL's clothes. She bypasses 5 laundry matts to get here. I tell my wife we should not have a $75 water bill. So the water would not fill in the washer. I told her to get a 5 gallon bucket and fill it up then see how many buckets it took to fill the washer. 7 buckets later the washer kicked in and started doing it's thang. 35 gallons of water to wash a full load on highest level. Then 7 more buckets to do the rinse. 70 gallons of water to wash one load of clothes. I figured I had her cured from coming over every saturday just to wash clothes. But she found out I fixed it. LOL She has a washer and dryer at her house but IF she goes overs a certain amount she uses then the trailer park charges her extra for water. Soo she comes ta my house. Sweet.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 11, 2011 | Kenmore Washing Machines
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
What is the capacity of my Kenmore washer?
3.2cu ft.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Are you happy with the Kenmore 800 4.0 cu.ft. top load washer?
For large capacity, a front loader would be your best bet. An HE2 by Kenmore should be sufficient. If a toploader is overloaded, it's more likely to do damage. Also a Whirlpool Duet would work. Whirlpool makes Kenmore, so shop for the best price, (they are the same inside)
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Super Capacity stuck on rinse
Krom, sounds like the machine is syphoning. Check the drain hose and make sure there is a air gap and that it is not too far down the standpipe or drain. To test it hold the drain hose right at the drain top and see if the problem stops...Catriver...post back.
Jan 18, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
173 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
