Question about Car Audio & Video
My cars battery has been disconnected 7 safe appears on the radio. I have the code and have tried resetting it but to no avail. please help. amanda
  • 4,886 Answers
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
this may be several hours
Posted on Aug 04, 2010
Had to reset my mini max to stock. Now showing all codes for exhausted but all that been replace. What to I need to do now?
Hi Amanda, When you get an error code and that problem is fixed you need to reset the codes by disconnecting your battery, The thing with disconnecting your battery is you loose your car settings IE: radio, electric seat... Make sure you have your codes...CHEERS..
Mar 30, 2016 | Mini Cars & Trucks
Please someone give me a unlock code for ford 6000ne car radio.YS4F-18C815-AD. serial M178227
It is only available at a Ford Dealership...Give them your VIN Number & they will give you the code...There is a charge for this service...Now, if you lost battery because you changed or disconnected battery you can avoid this happening in the future...Take a 9 volt battery...Remove the snap top from an old smoke detector...Solder the + lead to positive of cigar lighter plug and - lead to negative of cigar lighter plug...snap on 9 volt battery and plug into lighter BEFORE disconnecting car battery...The 9 volt battery will hold radio up while car battery is disconnected...saailer
Jun 05, 2015 | Ford Cars & Trucks
I disconnected the battery from my 2001 Volkswagen golf V5, now i dont know the code for the radio... can anyone please help..!! (:
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of VW radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
May 12, 2011 | 2001 Volkswagen Golf
My radio is in 2 SAFE mode on my 2004 Audi TT. My mechanic had to disconnect the battery to replace some parts on my car. when he turned the car on the radio was in 1 Safe mode. The code in the manual he...
IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for Audi radio is:
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Nov 20, 2010 | 2004 Audi TT
2001 Audi A4 radio in safe mode. Battery was
sorry to say, you will need to take it in, it needs to be hooked up to their computer to reset and have it start up poperly. It just like a pc when it crash it will try to start in safe mode until you select "Normal" start up
Oct 13, 2009 | 2001 Audi A4
VOLKSWAGEN RADIO IN SAFE 2MODE
call the dealer with this info and they will gladly give you the code
Mar 09, 2009 | Car Audio & Video
Radio reset code for 1998 a4 audi
I had the exact same problem on my 1998 Audi A4 Quattro Sedan I just purchased. I read a couple of other posts that said to try looking for the radio code in the spare tire compartment in the trunk. Sure enough on the right hand side of the compartment was a information label and on it someone had written the code 1174 in pen. I then left the key in the ignition and the radio on for an hour. Then I pushed the DX and FM1/2 button and the same time until the "1000" number appeared on the display. Then I pushed in the code 1174 using the 1 - 4 tuner buttons. For example the number 1 key I pushed until the number 1 appeared. Then pushed button number 2 until the number 1 appeared, pushed button 3 until the number 7 appeared and button 4 until number 4 appeared. After I had the code 1174 on the display, you again push the DX and FM1/2 button at the same time and the radio unlocked and worked perfectly. I hope that this helps. I have the Delta (Bose) AM/FM Cassette radio in my car. Good Luck!!
Mar 04, 2009 | 1998 Audi A4
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
