Question about IBM NetVista PC Desktop
I have a problem!!!!
I have a NetVista 8307, but when I power on my PC I see the BSOD (said ACPI need disable.) How to disable this?
Thanks in advance.
  • 56 Answers
In the bios
Posted on May 22, 2008
Descriptif 8307 73g
cobra software or 3dp pro
Oct 03, 2013 | IBM NetVista PC Desktop
How to turn off acpi mode during the installaition
When you first start the XP install, you are in 'text' mode - you know, blue and white screen, no graphics.
When you get to the point where it says at the bottom "Press F6 to install additional storage drivers", just hit F7. Change your system type from ACPI compliant to Standard Computer in the menu that comes up.
Is this message received on an existing installation OR are you now trying to install XP - that "during text mode set up" refers to the install.
If it is already installed Press F8 and select Safe Mode.
If you get in XP there go Start, right click My Computer, click properties, click the hardware tab, click device manager and on the My Computer expand the + sign.
If it says ACPI there, then it already is ACPI compliant.
This actually stands for "Advanced Configuration and Power Interface"
The issue is more than likely a driver, memory or possibly a flat CMOS battery.
hope this helps
Sep 17, 2012 | IBM Netvista M42 8307-81U Pc - XP Pro - P4...
I formatted the PC. 8307 41G IBM Netvista. Now the LAN card does not respond.
go to device manager by right clicking on "my computer" in start menu and clicking manage,the ethernet driver should be missing,download the appropriate drivers for all devices with a yellow question or exclamation mark and install,peace
Aug 24, 2011 | IBM NetVista PC Desktop
Will not power up when network cable attached
There is a Wake On LAN support on netvista 6792
and possibly this may be the reason
First, go into your BIOS, find the PnP hardware settings and disable Wake-on-LAN (it may be in a different category depending on your BIOS).
let me know if this has been perfrom
Jan 28, 2010 | IBM NetVista PC Desktop
Netvista pc would not start
Hi there.
If you have brought your machine from a different country and it was working there, then chances are you will need a new power supply that is matched to your countries voltage, most countries have either 240v or 130v, you will have to check into this! be careful however as you can blow the motherboard up if you use the wrong voltage.
My advice would be to purchase another power supply from where you live and install that one.
Good luck and thanks for using FixYa!!
Mar 23, 2009 | IBM NetVista M42 PC Desktop
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Ibm rear audio
My IBM NetVista 8307-P8G SoundMax Driver Not Support 5.1 speaker settings. pls help me
Dec 08, 2008 | Computers & Internet
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a...
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Regards.
Nov 16, 2008 | Acer Computers & Internet
Netvista AGP slot disabled
I added an FX 5200 256Mb AGP card to a 8307, and the Bios allowed me to enable the AGP port. And reports the device working properly.
May 26, 2008 | IBM NetVista PC Desktop
IBM NetVista PC Desktop Logo
161 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
