Question about Sub-Zero Refrigerators
Refrigerator is not cooling at al. Light works but that's about it. got a quote but looking around for better prices. Was told.... "Needs new evaporator, acso filter & freon 12" The quote for fixing it was astronomical from this place and I wanted to check around but every place I call won't give a quote on anything (even) parts over the phone and I don't want to waste another $75 trip fee for someone to tell me the same thing I already know.
  • 50 Answers
SOURCE: GE side-by-side Refrigerator too cold, runs all the time
If the problem is in the vegetable crisper drawer primarily, Google "WR49X10045". This is a simple fix kit for a design flaw.
Posted on Dec 21, 2007
SOURCE: Samsung Refrigerator
I have a RS2544SL side by side Samsung with a defrost sensor failure light upon a plug-in reboot, according to the service manual, which I purchase from Samsung so that I could help a local service provider unsuccessfully fix the unit.
The unit was less than 3 years old when I started having problems. The freezer side works although the unit will not re-boot following a power outage because is hangs-up on the defrost sensor flashing light on the front display.
Samsung service providers have stopped working on Samsung refrigerators and Samsung would not suppor the repair.
I had an independent service provider install a new defrost sensor but the reboot-pluging program still hangs-up at the defrost sensor despite a newly installe defrost sensor from Samsung.
The freezer side continues to work well and problems continue with the refrigerator side. The unit continues to fail during power-outages because it hangs-up on the warning light. I by-pass by holding both power freeze and power refrigerator buttons for 10 second as described in the service manual. After by-passing the warning light, the performance of the refrigeration side continues to be unreliable.
What is my next step to get my relatively new Samsung side-by-side refrigerator fixed, since Samsung will not back their warranty and Costco where I bought the unit also will not backup the warranty and purchase.
Posted on Jun 11, 2008
debihendrick
SOURCE: Sub-zero Refrigerator Door
We have the same problem and were told to apply vaseline to the rubber edges of the door; this did help.
Posted on Sep 27, 2008
  • 63 Answers
SOURCE: Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Posted on Mar 20, 2009
SOURCE: Need help finding the defrost timer in GE fridge !!
frigidaire Model frs22zrg Water leaking into the the dispenser (where you put the glass. Also the ice dispenser become iced and where the ice comes out.
The moisture is inside of the freezer part, may need a time or the heating coil is not working.
Posted on Aug 08, 2009
Freezer and Upper and Lower ice makers not working
that's a serious problem and I believe you need to either get a new refrigerator or have a technician come and give you a better diagnosis than me trying to find out what the problem is I look for parts and I don't think that model offers too many repairable parts for the evaporator an example is the defrost heater is part of the whole price of the evaporator
Appliance 911 Sea Breeze
Dec 04, 2015 | Samsung RF268ABBP 25.5 Cu. Ft. French Door...
My Panasonic Over the range microwave Model NN-H264SF front touch pad don't get any beep plus i cannot put any number so microwave don't work. If range get over heat microwave exhaust fan get activated...
it needs to be repaired others have had the same problem.
here's one review...
liked this product very much, until it died after a little under 1.5 years. I brought it to a repair center recommended by Panasonic. They quoted me a parts-and-labor price of around $125 to fix the thing. The repair included a new membrane pad (the buttons on the front), new fuse, and new fuse holder.
The repair center told me they've been instructed by Panasonic to replace all old fuse holders with newer, better ones. Apparently, the original fuse holder was somewhat defective, causing the fuse to burn out. I don't know if this bears any relation as to why a relatively new membrane pad might have gone bad, but it's certainly annoying for a device costing several hundred dollars.
Feb 07, 2018 | Panasonic Microwave Ovens
I have a Kitchen Aid refrigerator model KTRS20K which stopped working (everything felt warm and freezer not working ). I replaced the defrost timer, it didn't quite match but was told it was a re
That does not sound like a defrost timer problem. Sounds like a condenser or evaporator fan is beginning to fail. They don't always stop when they fail. Many will slow down and stop while you are not looking causing the refrigerator to stop cooling for a while. Let me know if you have any questions, Thanks Sea Breeze
Feb 12, 2012 | KitchenAid Refrigerators
CALLED A REPAIR MAN OUT. REPAIR MAN SAID THE "COMPUTER PANEL" IS BROKEN AND NEEDS REPLACED, THE FRIDGE/FREEZER WERE NO LONGER COOLING. ONLY HAD FOR 3 1/2YEARS! SAID W/B $600 TO GET NEW PANEL....
Rare but possible. I suggest that you order the part yourself and call a serviceman to install it for you. That may be a way to circumvent paying such an exorbitant price for servicing.
Dec 22, 2010 | Maytag MFI2067AES Stainless Steel Bottom...
I had a bad vibration whenever i would apply the brakes so i thought it was the front rotors. well i took it to a repair shop and they told me the rear drums and shoes needed replaced and also the front...
That sounds high to me but this is the kind of thing that dose not have to go to a dealer. Shop around for a better price. Check with independent brake and muffler shops. Do this by just calling them and asking what it would cost to have the following work done; front rotors machined, new front pads, rear drums and rear brakes. To be on the safe side also ask about the price to replace the front rotors as sometimes you have to replace them too if they are too far gone’ worn, gouged or warped. Make sure you are comparing the same work at each shop and also get information about the warranty (many places offer life time parts but may gouge your on labor when you come back). Once you have the shops rated by price and warranty go the one of your choice and have them give you a brake inspection and tell you want needs to be done. You don't want to be the one telling them what needs to be done unless you are 100% sure of the needed work. If there are big differences in prices for the work on the front and the back between shops you can have one shop do the front and the other do the rear brakes Depends how much effort you want to invest in gathering prices. Just be sure the shop tells you want needs to be done. By the way, the vibration that was your original problem is most likely warped front brake rotors.
Feb 27, 2010 | 2006 Chevrolet Silverado
Bushings are starting to go in the low arms. I've been told they're molded into the low arms (not available separate). Was quoted around $400/cdn for each low arm, seems very high. Was also told I could...
Wreckers normally look to sell at about 1/2 the cost of new so the prices you put in your query would be right. Some wreckers will discount a little more if you are willing to take the parts off yourself. The only thing is that if you wreck them taking them off you still bought them. Hope this helps.
Oct 28, 2009 | 1994 Mercury Villager
Maytag french door fridge crapped out....again
buzzing sound comes from freezer fan or ice maker fan. They are located behind the freezer rear wall. These freezer fan cools the freezer and the refrigerator. The ice maker fan supply air to ice maker.
Jul 22, 2009 | Maytag MFD2560HES Bottom Freezer French...
Freezer cool but not cold
It sounds like it is due for a shot of freon (or most likely R-134A), and most fridges have a crimped coolant line instead of fittings to connect to for recharging. Call a few refrigerator repair guys and get some quotes, and then compare the price of a new, more energy efficient fridge. You will probably decide you are better off just buying new, considering the average life span of white goods is around 10 years, and no telling what will go bad next.
Jun 08, 2009 | KitchenAid KSRG25FKSS Side by Side...
Dometic refrigerator
The system is sealed very difficult to charge. Not to mention expensive. The same price to get a new coil. The boards that control the operations are hard to trouble shoot sometimes. Do you have 12 Volts DC going in to the control board. If yes does the control board inside show green lights that it is working. If so the lower control board on the out side needs to be looked at.
Sep 04, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
