I purchased a Targus USB 4-Port hub for use with my iMac 24" computer (new), using iMac OS 10.5.2. There is a power input connector on the hub, but no mention of power requirements on the package Please describe need for power if any -- am assuming it may be needed for Mac portables? And source for power supply if power is needed. Thanks, John Brougher 214-368-7242, email johnbdal@att.net
    Master:
  • 351 Answers
Dear John,
this USB hub don't need any external power, but you are right there is a power input connector comes with every Targus Usb hub. but these hub self powered . you can use this hub without any worry.
Regards
Posted on Apr 26, 2008
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
Targus 4-Port not working
First off hubs don't support a lot of power hungry devices so you should be able to buy an optional power adapter for the hub on targus' site.
Second if your computer doesn't have any usb 3 ports then the hub will only operate at usb 2 speeds.
Your probably overloading the hub. Buy the power adapter.
Dec 22, 2012 | Targus 4-port USB Hub Group International...
I bought a 4 port usb hub targus and it doesn't work with my windows 7
Right click on my computer or the icon for my computer and select manage then open device manager and see what it says in there then up top select check for hardware changes icon, this should look for and install the hub
Jan 01, 2011 | Targus PA055U 4-Port USB Hub
I DON'T KNOW WHERE TO PUT THE USB CONNECTOR
If you only have one USB connector then you can purchase an USB hub which may have 4 or more ports (I suggest you get a powered USB hub). Then plug the hub into the computer's USB port and you now have several USB ports.
Jan 04, 2010 | Canon CanoScan 4400F Flatbed Scanner
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
One day the Belkin 7 port hub works the next day it doesn't
Your problems with the Belkin 7 port are not due to the Dell computer or the XP OS. To problem solve, select on USB port and stay with it, not the 2 top ports for your keyboard and mouse. 1. Plug in the power adapter, wiggle it about, widen the prongs, change outlets at the 120 v. end. 2. Use an simple hand magnifier and peer closely at the DC input plug and be positive that the center post and the minue side piece of metal if in firm constact with the plug. If cannot insure a firm fit, sligtly bend that tiny metal piece towards center. Option 2, use another adaptor with the precise voltage as the original and the idential pin that inserts into the module. 3. Use another or new USB connector.
This list does not imply a specific order of diagnosis. Your fundamental problem is the failure to delive DC power to the Belkin hub or to capture the hub to USB port signal. In a phrase, you gotta short somewhere.not an issue with the computer or the XP operating system. Bill Miller
Aug 25, 2009 | Belkin (F5U237) 7-Port USB Hub
I have Entrega hub 4U circa 1998. Warning "too high current draw.....will disable usb port 2007 duo core imac using OS 10.5.6. can I use this device or is it incompatible? Still works fine on 1998 ima
its just warning you that the hub is sapping too much power from the imac, newer hubs are only a couple of $$ and are much more power efficient, try somewhere like dealextreme.com
Apr 18, 2009 | Computers & Internet
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Targus Travel USB 2.0 4-Port Hub with Notebook Light
I'm sorry to tell you your hub cannot be fixed. I have one just like it and have taken these things apart and repaired simple factory errors as loose wires and the such.
You should get yourself another Targus brand USB hub. They are good and quite reliable
Regards,
Worldvet.
Jun 08, 2008 | Targus 4-PORT TRAVEL USB 2.0 HUB...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
