Question about Hitachi Televison & Video
I have a purpleish colored spot in the center of the screen. What can I do to fix it.
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
If it is rear projection set, you may have a burnt tube; what happens in some models is a arcing may occur and it burns a spot in the center of the tube.
In this type of set there are 3 picture tubes (what is model number?) The way in this case to confirm this is remove the back and with the set turned on (BE CAREFUL!) YOU cover the three large lenses with a cloth one at a time----if one of the tubes is burnt when you cover that lens the spot in the center of the screen will not be seen.
If this damage is there it is permanent---the tube would have to be replaced AND WHATEVER ARCED WOULD HAVE TO BE FOUND AND CORRECTED.
LET ME KNOW IF I CAN HELP---I am here to help.
SD TECH
Posted on Aug 04, 2010
I own a Sony KDF E50A10 3LCD TV that has developed a purpleish defect in the lower, center portion of the screen. Do you have any ideas on how to fix this?
It is an Optical Block Problem, Sony has settled several Class Action Lawsuits covering many models from 2002-2010. Start with this Link, it will provide you a very good starting point. Hope this helps
http://sites.google.com/site/sonylcdrptvproblems/
Jun 01, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Spot in center of screen, if the color pictureis black the spot is blue, if the picture is white the spot is yellow.
Spots in screen is commonly caused by defective LCD on the optical assembly. LCD replacement is very difficult. I suggest to contact the nearest service center at your area.
Oct 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Poor picture no color
OUCH! LARGE DARK SPOT IN CENTER IS NOT GOOD FOR PROJECTION TV. YOU BURNT THE TUBES. THE LOSS OF COLOR IS THE ROOT CAUSE SOUNDS LIKE A DEFLECTION CIRCUIT PROBLEM. THE TIMING FEEDBACK IS USED TO SYNC THE COLOR CIRCUIT. IF THE TUBES LIGHT WITHOUT DEFLECTION THEY BURN THE CENTER PHOSPHOR COATING INSIDE.
Dec 24, 2009 | Televison & Video
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Blue haze/cloud in center of screen, slowly spreading
how to fix my problem Blue haze/cloud in center of screen, slowly spreading .but last time my lamp broken I order by my self and fixed now I have the blue color in my screen please let me know what is the problem may be I need to replaced same parts please let me know how to fix thank you
May 13, 2009 | Hitachi 55VS69 55" Projection HDTV
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
COLOR
damaged shadow mask inside CRT==not worth fixing!
Sep 25, 2007 | Panasonic CT-35G25 TV
Blue Spot in top center of screen
same problem, guy said i need a COLOR DRIVE!! $1000, trying to find cheaper
Jan 07, 2007 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
