Question about Hitachi 57G500 57" TV
The internal speakers don't play. Have been using external speakers now what to use internal speakers. I think there is setting wrong any indeas
    Problem Solver:
  • 9 Answers
Hello Dear,
I am well pleased to contact you after viewing your profile,which really interest me to communicate with you as a genuine friend, this is my e-mail address (aw.sesay@yahoo.com),
i wait to hear from you soonest.
Awa.
Posted on Aug 04, 2010
I have a brand new 55" smart TVs and when we set it up we could not get any sound,is there something we are doing wrong.
Check in the menu if there is a switch between internal and external speakers. If you are trying to use the internal ones and they are set externally, you will get no sound. The reverse is also true.
Jul 30, 2016 | Televison & Video
My organ wont sound but if i use a external amplifier he will play could be speakers ?
Probably internal amp or speakers are defective. Try other speakers and if they are not getting sound then it may be the internal amplifier but check your settings to make sure you don't have the internal speakers switched off on your menu or control setups.
Hope this helps.
Oct 07, 2014 | Audio Players & Recorders
External speakers don't work
If the set has a connection for external speakers they have be the same impedance (ohms) and the set will likely have to be switched from internal to external.
Dec 10, 2012 | Televison & Video
Sound not working on my UMC 23inch tv
Simple things to check:
Speakers in menu not switched "off"
Sound not muted or low either on the SET or BOX if used.
Internal speakers not switched to External (some sets have this)
If a DVD etc plays with sound set is ok and some setting is wrong.
Apr 18, 2012 | Televison & Video
No sound on monitor tv. Does it have internal speakers or does it need external speakers hooked up to it? Also, i need help configuring it so it will play audio
Set indicated here has speakers and may have a slide switch on rear to select internal or external speakers.
Also in menu look to see if speakers are switched off.
Apr 03, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Gateway Internal Speakers Stopped Working
click on Start / Control Panel / Sounds And Audio Devices
look at Speaker Settings / Advanced -- be sure it is set to your internal speakers.
the tabs across the top; go to Audio. -- be sure it is set to your sound card. For example, mine is "SoundMax Digital Audio" ... If there is another device you use that plugs into your USB, it could have stuck on "USB Codex". If it is, just put it on "NameOfSound Card" ...
Good luck, Don't be afraid to look all around inside the Sounds And Audio Devices box. And is this helped, please take a sec to rate me. Thanks!
Don
Mar 18, 2012 | Gateway Computers & Internet
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
Need Help with Souround Sound 5.1
Double check your TV settings and ensure that you have your audio set for internal and not external. The external setting would only be used if you have external speakers connected.
Aug 08, 2009 | Audio Players & Recorders
Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Nov 06, 2008 | Computers & Internet
Hitachi 57G500 57" TV Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
