Question about Refrigerators
I HAVE A 1992 KENMORE REFIGERATOR TYPE 22 SS A 92 WITH THE ICE MAKER AND WATER. DID THIS PATICULAR MODEL HAVE A WATER FILTER BUILT IN. IF SO WHERE WOULD IT BE LOCATED?
    Sergeant:
  • 216 Answers
Generally a filter is a add on feature. If you do not see a filter in the water line that supplies the ice maker then there is generally not a filter. You can purchase a water filter from any local hardware store and install it yourself.
Posted on Aug 04, 2010
My kenmore refigerator ice maker stopped making ice.
Could be that the solenoid that feeds water to the ice maker is not working properly.
Also make sure that the freezer temp is at least 10 degrees or less - if not the ice making cycle will not commence.
Mar 12, 2017 | Kenmore Refrigerators
After I run the cleaning cycle on my kenmore ice maker model, water is still in water pan and the unit will not make ice.
Here is a link to a Service Manual=>
15 inch and 18 in Automatic Ice Maker Service Manual
and then go to page 22 where the diagnostics begin. I am here if you have questions. The manual is very informative Thanks Sea Breeze
Dec 14, 2012 | Kenmore 51lb. Clear Ice Maker
Our ice maker leaks water and forms mini iceburgs inside our frezer. It appear to a water leak leading to the ice maker. What part should we replace to fix this problem. It is a Kenmore SxS 26' SS...
Your water valve probably has a drip like a bad water faucet.The water valve is cheapest and your only 2 parts options are the ice maker AND the water valve.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2011 | Kenmore 57703 Stainless Steel
I have a Kenmore side by side, model # 106.57032601 that I bought 4 years ago. The ice maker suddenly quit working. The refigerator/freezer work fine otherwise and I continue to have water from the...
Is your ice tray filling with water? If not, then I would suspect the water inlet valve (http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657032601/0582/0165000/K0607002/00012?blt=06&prst=0&shdMod=10657032601 - Item 10)
If it does fill with water, but does not eject the ice cubes to start a new cycle, I would suspect the ice maker motor(Item 37). BUT if it is the motor, that part costs $91.22 and you can replace the entire ice maker (Item 100) for $157.95
Jul 10, 2011 | Kenmore Refrigerators
I have a GE Profile refigerator ( model # PSCS3VGXAFSS ). I have had it for a year. It is still under warrenty. The question that I have is that the ice maker just stoped making ice. It goes through all of...
There is a dual solenoid water valve. One solenoid controls the water dispensor the other is for the ice maker. If its under warranty you should definitely have it looked at.
Sep 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
No ice is being made.
Most likely either water valve is bad or ice maker is bad. You would need to determine if Ice Maker is sending voltage to water valve. If it is, replace valve. If it's not, replace ice maker. Also be sure filler tube going through back wall is not frozen. If it is, replace water valve.
Sep 02, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
Cant find the ice maker filter on my kenmore elite bottom-mount refigerator
It is on the back - behind a removeable panel. Top left side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I can get water to the water dispenser in my side by side. but it will not make water. It's a Kenmore 22 side by side. I believe the model number is 9522611. We switched the wires on the solenoid and it...
the inlet water valve has a screen on the inlet in the valve which is probably clogged - replace the inlet water valve with a new one, install a ice maker water filter in the water line feeding the ice maker!
Jan 15, 2018 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
My maytag refrigerator sidebyside ice maker stop working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnc
Jan 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Kenmore Refigerator Ice maker
First, ensure that you have water connected to the intake tube at the back. The water filter needs to be checked also. It is in the cooling section(not the freezer), at the top. If it looks old or water does not flow, it will need replacing. Depending on the model, there is a switch inside the freeze section behind the ice tray. Turn that on, and ice should be available after a few hours. Some models don't have a switch, but a wire hanger, that needs to be in the down position for the ice maker to work.
Aug 29, 2007 | Refrigerators
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
