Question about Cameras
My DMC-FS42 is off and the lens is out now it doesn't turn on or do anything
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 04, 2010
Remove front cover Lumix dmc-zs7
This camera doesn,t had a front cover at all maybe the lens has a cover.Just turn it on and the lens open automatically
Jul 16, 2013 | Panasonic Cameras
My lens won't close on a lumix DMC-TZ5
Here are troubleshooting steps for that issue:
Dec 14, 2012 | Panasonic Lumix DMC-TZ50 Digital Camera
Horizontal lines while takin a picture with DMC-FS42 plz do let me know da solution for diz asap.....
When that happens it is usually better to replace your camera. Image sensor is broken. You can TRY restoring your camera to factory settings.
Aug 10, 2012 | Panasonic Lumix Cameras
Panasonic DMC-FS42 broken hinge on usb cover - can it be replaced?
You may go to modDIY.com for any jack cover replacement. It costs $0.6 only with current promotion!
Nov 03, 2011 | Cameras
I need a manual for a panasonic lumix dmc-fs42 camera
Get the manual for your camera by clicking here to download.
Hope this helps.Thanks!
Please rate this answer.
Oct 23, 2011 | Cameras
What is the part number for a panasonic lumix dmc-fs42 lcd screen?
The part number for the LCD screen (display) is: VYK3H41
For more details and part numbers, click here. Enter dmc-fs42 under model number.
Hope this solves your problem. For more help and clarifications, please feel free to reply to this post.
Thanks for using FixYa.
Jun 30, 2010 | Panasonic Lumix DMC-LS80 Digital Camera
Camera says turn off and turn on panasonic lumix dmc-fs5
While you are turning the camera on, hold the lever which you use for zooming in. The lens should extend before you get the annoying message about turning the the camera off and on. Then, gently apply pressure to the lens as if you wanted to push it back to the camera. While you are doing this, turn the camera off (lens should come back into the body of the camera). This will solve your problem.
Thank you!
May 17, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Changing the time
Press MENU/SET in Normal Picture Mode. Press up/down to select CLOCK SET. Press right. Press left/right to select the items and up/down to change. Press MENU/SET when complete.
Apr 29, 2010 | Panasonic Lumix DMCFS42 Digital Camera
I have a panasonic DMC-FX5 memory card error
I'm assuming the slide switch on the side of the card is in the unlocked position. Have you formatted the card in your other camera or does the card contain pictures taken on the other camera? This could be the problem. To get the card to work in your FX5, download any pics from the card to your computer and then, format the card in the FX5. In the future, don't use the card in more than one camera.
Jan 14, 2010 | Panasonic Lumix DMC-FX5 Digital Camera
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
