Question about Dell E773C 17" CRT Monitor
My dell e773c monitor does not show a clear picture. all pictures look animated. how do you adjust. driver downloads wont fix it. it is on my computer not this one.
Power off
Posted on Sep 09, 2010
My dell monitor ultra 2000 goes blank after about 3 minutes then i turn it off and on again. the picture will show but have to keep resetting it. is it repairable?
Everything is repairable but CRT monitors are not worth repairing. Just about any thrift store or recycling center will have a load of them and most of those places won't even take them any more so it's real easy to find a free one.
Feb 18, 2011 | Dell E773C 17" CRT Monitor
Picture not adjusting to full screen an dmonitor buttons Exit, brightness, contrast and Menu are not working also. Checked all buttons contacts are ok.I tried to search for vertical and horizontal variable...
You will need to reset the resolution to fill the screen. That is done through Windows.
If the actual menu buttons on the screen are not working, you probably need a new monitor.
var fctb_tool=null; function FCTB_Init_5ddec69ff7a64d918e9c62baf4d86075(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_4b77af1c80d64567931291644b9994c7(t) { fctb_tool=t; start(fctb_tool); }
Dec 18, 2010 | Dell E773C 17" CRT Monitor
The monitor functions only for 15 seconds then you don't see anything
The picture board on your monitor is bad, since the power led or button is on and all connection are correct the monitor only display for 15 seconds before going blank, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jul 04, 2010 | Dell E773C 17" CRT Monitor
No picture on monitor (monitor turns itself off)
You will need to take it for repairs.
Sorry
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Dell E773C 17" CRT Monitor
How do i get to backlight
Are you sure that the back lights are bad, there are 4 lamps inside (2 lamp assemblies, top and bottom).
Please look at my pictures here so you will know what to check.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
http://s807.photobucket.com/home/budm/allalbums
Apr 17, 2010 | Dell E773C 17" CRT Monitor
My Dell E773c Monitor's image is like a "hyperbola" wider at the top and bottom and narrower in the middle. The Horizontal adjustments do not do anything to correct the problem, Help!!!!
Try to do a factory reset (look up "recall" in the manual, or here: http://support.dell.com/support/edocs/monitors/e773c/EN/ug/setup.htm).
If this does not help, you need to adjust the geometry settings (H/V position, H/V size, rotation, trapezoid, parallelogram, pincushion and pin balance) using the monitor's settings menu. Expect a long afternoon of fiddling around until you get a satisfactory result. A test picture for geometry settings could be of help.
Make sure your computers video setting does not exceed the monitors specification of 1152 x 864 @ 75 Hz.
Feb 04, 2010 | Dell E773C 17" CRT Monitor
I reinstalled XP on my Dell. How do I get the e773c monitor to work. It uses default monitor software. The CD that came with the system has no setup icon. I donloaded a driver but the download has no setup...
you can format the system bt any document save on the system vanished as you do,if copied any useful document into removable devices, then you can now get the software in the software market and reinstalled it to the system.waith and see it work.
Jul 09, 2009 | Dell E773C 17" CRT Monitor
Dell Monitor E773C
on dell monitors they have buttons on the front (at least the old ones do).   If you can't see things on your screen like task bar on the bottom, or anything on the top and sides --- try adjusting this buttons.  They control vertical size, horizontal size, etc. -- also position on the screeen    If you accidently hit them (I did) it throws everything off.
good luck
May 23, 2008 | Dell E773C 17" CRT Monitor
Dell E773C 17" CRT Monitor Logo
60 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
