Question about Logitech Computers & Internet
When I left click, it sometimes (not always) responses as if I double clicked it.
    President:
  • 2,571 Answers
Check the setting in Control panel / mouse. OR the software provided if the mouse came with any ( usually only if it has extra buttons and functions)
Posted on Aug 04, 2010
How can get driver for Wind XP
There are no drivers user loaded, the instruction is in the cd / dvd disk drive already from the factory, but when you load the OS, it has some included... these have been known to become corrupt or filtered...
In case windows no longer recognizes the cd dvd disk drive, as if the disk drive driver were erased...
left click start in the lower left hand of the screen
left click run
type regedit
left click OK
Now the registry editor will come up
double left click on HKEY_LOCAL_MACHINE
double left click on SYSTEM
double left click on CurrentControlSet
double left click on Control
double left click on Class
double left click on {4D36E965-E325-11CE-BFC1-08002BE10318}
look on the right side of the window for upper filters
right click on upper filters
left click delete
windows will then ask you to confirm deletion
click yes
look on the right side of the window for lower filters
if you do not see lower filters, you may be out of luck on this one.
right click on lower filters
left click on delete
windows will then ask to confirm deletion
click yes
Close all the windows that are open
restart the computer
In many cases that solution worked, in some cases setting the system back to a previous time, using system restore, was able to reset the system to the time before the system stopped recognizing the drive.
Jun 04, 2013 | Computers & Internet
I have a manhattan wireless mouse, model number 176811. the pointer works fine but when i double left click to open anything nothing happens, i have to hit the button 3 or sometimes 4 times to open file??
You may not be double clicking fast enough. In the Windows System Control Panel, there is a Mouse Settings control panel. You can adjust the double click rate in the Mouse Settings control panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Aug 12, 2011 | Manhattan Mouse
MFC 790CW can't cancel my print request
This is a Very Common Problem.
Two Ways... The first is easiest, but doesn't always work:
  1. Reboot Computer and Reboot Computer (works sometimes) Windows has had this quirk for as long as I can remember.
If that didn't work, try this each item within
  1. , then Right Click , Click .
  2. In left column Click , Click
  3. In right column Scroll to/Double Click , Click
  4. Since you didn't tell me your Operating System Follow This Route
  5. Open Internet Explorer aned type this: C:\Windows\system32\spool\PRINTERS (DO NOT type it into the IE window you are reading this in; either open a new tab or new IE window)
  6. Highlight print job you want to remove (or after Highlighting one of them) to select all, then to delete.
  7. Repeat
Mar 11, 2011 | Brother MFC790CWG1 / MFC790CG1 Printer
Hi . I have a Wacom Intuos 3 tablet with a zc-100-00 mouse. When working in alot of graphics programs illustrator especially, I notice when I click on an object sometimes it reads as a double click... ...
Sorry to read about your problem, I hope this helps you out.
check you setting's that it is not set for double click
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Wacom ZC100 Mouse
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
When ever i click the left button it double clicks
You can alter the double click setting by going to Control Panel - Mouse and move the slider for the Double click setting to the left to slow down the click response.
Dec 24, 2009 | Targus AMW15US Mouse
I've had the acer one for 2 weeks. While using it today, the single and double click functions of the touchpad stopped working. The touchpad still moves the arrow around the screen and the left and right...
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
Toshiba double tap is not working so i have to always click
Go to control panel>folder options>general tab and you can change it back to double click.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 08, 2009 | Acer Aspire 5610-4648 Notebook
My D & E drive is not opening on double click.
parental control pin codes for the box so the new codes can be installed
Dec 28, 2008 | Computers & Internet
Have got a printer HP Destjet F 2100series F4100series cannot get the disk to work it is a new one the book tells me to click my computer double-click the cd-rom icon but i cannot find this can you help...
Left click "START" button
Left click "My Computer"
Double left click the CDROM icon (Picture of a CD)
This will open your CDROM disk, look for setup.exe and double left click it.
If you can't find a setup.exe, look for the autorun file double left click it and in that file should be the startup file and location.
May 09, 2008 | Office Equipment & Supplies
Computers & Internet Logo
41 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
