it turns on fine blue light good. It won't produce sound from the right channel. on the left channel it doesn't sound till it's all the way up and then it's like faint static with the beat of the song. it is hooked up correctly. Do I have to have my car started?
Those signs are not a good sign. From what you have posted, I would say your amp is toast. Check to make sure your subs aren't blown. Hook up a separate speaker to each channel to make sure it isn't your subs. Check your RCAs to make sure you don't have a nick in them some where. Just get any pair of RCA's that you know are good and run them directly from the head unit to the amp. Good luck.
-Andrew Hawkins
hi there, my name is adam. I recently bought an alpine typs s 1043d sub (10'') and an alpine mono...
(More)
hi there, my name is adam. I recently bought an alpine typs s 1043d sub (10'') and an alpine mono mrp-m500 amplifier. I was wondering a few things. 1) can u show me a wiring diagram or video or pictures as how to wire the sub to the amp. (because there are 4 pushposts instead of 2 like i had before) 2) how to set up wires for wiring amp and subs to a head unit and 3) what i should be setting my gain, bass eq, and low pass to if i listen to mostly hip-hop/rap music. thanks so much
i have a nissan avenir 2004 i have just installed a panasonic head unit i have not used wiring...
(More)
i have a nissan avenir 2004 i have just installed a panasonic head unit i have not used wiring harnesses i have cut the plugs off and put a choc block in place my problem is i now have no indicators or tail lights brake lights still go. Aerial is working as earth i have tried everything i can think of to fix also have one yellow wire with black stripe left over any ideas
