Question about Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300
Where to buy a transformer for a Homemedics massage cushion for model ADP 10 2 GB tead 57 122000V 12v 2a 24 va
Need a power cord for Relaxzen massage cushion model 60-2907P04
This is not just a "power cord", it a 12V 1A wall wart. You can probably get a suitable substitute on ebay, but you'll have to figure out what the size of the adapter plug is to mate with the Relaxzen cushion. See the link for a pdf showing this
http://goo.gl/IYaHnF
Jan 09, 2017 | Health & Beauty
How do i stop the clunking noise when rollers go u and down
Unfortunately, you will probably not be able to stop the noise as it's probably being caused by the track system that the rollers move on wearing out. The tracks are made of plastic, and over time they will wear out or break from use, especially if used daily, as in the case of the one of ours that broke from my wife using it daily for a number of years. I opened it up thinking that I might be able to fix it, but the track was destroyed and unrepairable. This is one of those items that are truly designed to be that way so that you will have to buy a new one once the one you have breaks. Sorry I didn't have better news. I have a perfectly good SBM300 here that's missing it's power supply, but those are also impossible to be found, even from Homemedics.
Jul 05, 2014 | Homedics SBM 300H Therapist Select Shiatsu...
What are the tolerances of a 24 volt transformer ?
Hello, a 24 volt transformer can handle a tolerance of about 10% or just a little under. The important thing to remember about transformers is to always replace one with the same VA rating ( VOLT-AMPERE)
Feb 18, 2011 | Heating & Cooling
About 2-1/2 years ago I bought two Fantom GF500EU drives from Buy.com. This week one failed. I swapped the power supply cord (with a transformer at the plug) and the cord was the cause. Where can I buy a...
If you just type in the manufacturer and the model number in your search bar there will be a multitude of places to get parts for this unit. Try to avoid the top few "sponsored" sites.
Dec 15, 2010 | Fantom Drives 120 GB Hard Drive
AC adapter voltage for Conair Heated Back Massager
It is a class 2 transformer
The Conair part number is TEAD-57-121600U
Input: 120 volts AC 60 Hz 29 Wats
Output: 12 volts DC 1.6 Amps
Sorry, I don't know where you can find one.
Jan 07, 2009 | Conair Heated Back Massaging System Bm1
Ilectrical problem
If I only used it for 10 min. and it stopped working? I would quickly throw it back in the box and find a store that sells them and demand a replacement. Or just buy the same exact model and then return the broken one to the store with the same reciept.
Jan 01, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
Homedics SBM 300H Therapist Select Shiatsu Plus Massaging Cushion SBM300 Logo
82 people viewed this question
Top Homedics Health & Beauty Experts
Charles T Nevin
Charles T Nevin
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
