Question about Whirlpool Washing Machines
I have a whirlpool duet washer 2 yr old--when i start washer, it will start and then stop--Sud code comes up and then another code F-35 comes up. I can unplug the michine for a few min. re-plug , and the washer works fine for that one load-- next time i use it i must do the same thing again--unplug and replug--can u help ,thanks Buster
    Brigadier General:
  • 3,513 Answers
Hi
Both of these fault codes point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after doing this, you will likely need to replace the pressure switch.
The error code F35 is commonly associated with the Sud error, which comes on within a minute of running any cycle. It means the Analog Pressure Sensor (small plastic electronic circuit) has gone bad. It costs about $99 to order from Sears although they are on backlog, or you can get it cheaper somewhere else. It could also mean the Air Pressure Tube from the Sensor has a hole or isn't connected.
Once you get the new Sensor, remove the 3 screws holding the top panel in place - they are on the backside on the very top. Remove the top and look at the far back upper right corner (looking from the front). There is a small crimson & black piece attached to the metal side wall with 5 blue wires & 1 black wire (pressure tube) attached to it. Make sure there are no leaks or disconnects...if not, then replace with new sensor - takes a little playing with to remove the old one & the wires. Replace lid, it will work like new.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 04, 2010
  • Buster Clark
    Buster Clark Aug 04, 2010
    Sounds correct, but i am a little confused about the un-plug and re-plug--and the michine works fine. Why would this happen (may-be clears the control panel) just strange it would start
    washing again.
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS ERROR CODE 35 OR ERROR CODE 37? ON MY FRONT LOADER.WFW9600TA00
does it say f35 and sud?
you need a new pressure switch
sounds like a new washer is it 1-2 years old?
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE A WHIRLPOOL DUET STEAM MODEL WFW 9600 TAOO. NO WASH CYCLES WILL START. I GET A FLASHING 'SUD' AND THEN CODE F 35. DO YOU KNOW WHAT THE PROBLEM IS? WHAT PART NUMBER DO I NEED? WHERE CAN I FIND IT?...
SUD, usually caused by using the wrong type of soap. Your soap should have the letters "HE" on front of box/bottle. SUD can also be a bad drain pump, question is, does it still have water showing in tub?
F35, is a pressure sensor # W10156252, good luck finding it, as Whirlpool has problem keeping these things in stock. They list price at $112.82. Only takes about 20 minutes to change. Research sears.com, select PARTS Direct, enter model number, click on cabinet parts, find analog pressuer switch, see if they have in stock. Or, research the net for someone that does.
Take top of washer lid off, pressure switch is located on top right rear side wall of machine.
Good luck.
Oct 01, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Sud code comes up and stops and just beeps
Are you using HE detergent (for all front load washers ) or regular detergent ? SUD means suds lock from regular detergent .
Jul 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stops during begginning of cycle with F 35 reading .
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Washing Machines Logo
22 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
