Question about Rocky Mountain Trophy Hunter 3 for Windows
Hello. Years ago I had Rocky Mountain Trophy Hunter 3 for PC when it first came out. Just a few months ago I was browsing Amazon.com and found it again. I purchased it, and tried installing it onto my home PC. Didn't work. White 'flashes' took up the entire game screen and made it impossible to find out where I was clicking. Today I attempted to install it onto my laptop. Didn't experience the same problem before, but rather a much different one. The game works just fine (through the hunter creation, equiptment, etc) until I've tried to go hunt. Then the program shuts down and I get this message in a pop-up. "A problem has caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." What exactly is the 'problem'? Does anyone know, and can anyone possibly help me with this? :c
    New Friend:
My Home computer is doing what his lab top is doing, NEED HELP ASAP
Posted on Mar 12, 2015
Try this for your home pc:
hi I just fixed this problem on my computer. Here is how I did it. I have an NVIDIA video card and I right clicked on my desktop, went to NVIDIA control panel. Under 3D Settings, I clicked on "adjust image settings with preview". Under that setting my original setting was "let the 3D application decide". I selected the 3rd option "Use my preferences emphasizing: (Performance/Balanced/Quality)" Originally it was set to "Quality". I moved it to Performance and tried the game and IT WORKED!!!!!!! I am so happy! Also for me the "Balanced" option brings back the white screen.
Hope this works for every one who reads this.
not sure about your laptop though. Try reinstalling? might work
Posted on Feb 06, 2011
  • Jeremy Deland
    Jeremy Deland Mar 12, 2015
I just installed rocky mountain trophy hunter versions 2 and 3 on my computer and am having problems with both. My computer is saying that RMTH 2 is not a valid win32 application and i cant install RMTH 3...
For RMTH2, make sure you have the 1.1 patch and try again. If it is still failing, copy Rmth2.exe directly from the install CD into the folder that has the same filename and overwrite the installed one.
For your RMTH3 issue, it is usually caused by older software not being able to find the temp directory. Try copying the setup files to somewhere like c:\temp and install from there or set your temp variable to c:\windows\temp instead of your profile temp folder.
Apr 19, 2017 | Rocky Mountain Trophy Hunter 3 for Windows
I have the game Ricky mountain Trophy Hunter (which I love). It works on XP but not on my new vista OS. What can I do to use the game on Vista
Your first port of call should be to try to run the game in compatibility mode. To do this:
  • Right Click on the shortcut
  • Goto "Properties"
  • Then goto the "Compatibiltiy" Tab
  • Select "Compatability Mode"
  • From the drop down menu, slect Windows XP
Try starting the game. This should allow it to run. If this doesn't work try re-installing.
May 06, 2011 | Wizard Works Rocky Mountain Trophy Hunter...
We have had our grinder 3 years. About 6 months ago it started leaking lots of ground coffee on the counter but still worked fine. Two weeks ago it just completely stopped working. It does not make a...
Hello Darla, if the grinder will not run or make a sound, it usually means that the motor isn't getting power. Make sure it plugged in of course but your main switch may have gone bad and needs to be replaced. As far as leaking grinds; you must have a bad seal between the doser and the mill housing. Feel free to give me an email if you need more info or parts.
Thanks, Mike Wall mikey@espressomachineexperts.com
Sep 15, 2010 | Rancilio Rocky Doser Espresso Grinder...
Can it be installed
well first are you running 32 bit or 64 bit win 7? there is a compatability mode on win 7 just like XP you right click on the icon that starts the game and go to the properties (does not work with the shortcut if you are on the shortcut there is a find target tab ) once in properties you should see a tab at the top that says compatability in there you can set it to 256 mode and to run like it is on win 95/ 98
Dec 08, 2009 | Computers & Internet
My Jeep 2007 won't start but the battery is good. How to troubleshoot. Where to start?
I had same prob with Grand Cherokee - no rhyme nor reason as to when, where or why it wouldn't start. After two new starters the shop finally found a starter wire/cable that was corroded on the inside. Mech' could move it back and forth and it would / would not start. Changed cable six months ago - no problems since. Hope it helps.
Oct 11, 2009 | 2007 Jeep Commander Rocky Mountain
Problems running Rocky Mountain Trophy Hunter 3: TotW
Apr 07, 2009 | Rocky Mountain Trophy Hunter 3 for Windows
No audio from rocky mountain c430 radar detector. need user manual or solution. volume control at max. visual indicator present...
Rocky Mountain Radar authorized to send in unit since it has 3 year warranty
and only 6 months since purchase.
Mar 06, 2009 | RMR-C430 Radar Detector
Rocky Mountain Trophy Hunter 3 for Windows Logo
489 people viewed this question
Top Rocky Mountain Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Rocky Mountain Video Game Console and Game Expert? Answer questions, earn points and help others
