Question about Ryobi Multi-Volt Battery Charger
Need to replace a capacitor in an 18 volt Ryobi battery charger #1423701 . The part # on the capacitor is R929 B2ES. Need to know the specs on the capacitor
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: 18 volt ryobi battery charger...green & yellow lights come on wha
talked to Ryobi and they are vague. It can either mean that the battery is bad, or the charger is bad and another one that maybe the contacts of the battery are dirty or not seating fully in charger. What I would look for in this instance first unplug the charger and look into charging slot to make sure the terminals of the charger are not bent and they come out into the cavity where battery would go. If not gently pull terminal into opening and retry. Sorry I couldn't be of more assistance
Posted on Dec 31, 2008
SOURCE: What is the replacement fuse for a Ryobi 18v charger?
The fuse in mine said 4 amp. I have also used. You can use a 4 amp or lower to replace the original one that blew.
Good Luck
Posted on Mar 22, 2009
  • 104 Answers
SOURCE: my 18volt Ryobi battery needs the inside batteries
Yes you can replace the inside batteries yourself , just take the old ones out and go to Battery world or a similar shop and get replacements then all you have to do is repack them yourself and put them back into the battery case .
Posted on Jun 12, 2009
  • 13 Answers
SOURCE: The Yellow and Green light both come on and stay
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more than 15 minutes it probably a defective battery pack. See page 8 in the manual.
Posted on Nov 24, 2009
Can I use my old Ryobi charger (#1423701) to charge my new Ryobi LITHIUM battery?
If the old charger has a deep-uncharge-protection contact and was also made for Li-ION ther is in any case a marketing technical design by a notch to protect the battery to place on the charger if this cells are not correct.
(this answer applies to all brands with a quality mark)
Apr 12, 2016 | Ryobi Drills
No light on charger when plug in battery to charge? Charger No. 1423701 with p103 battery. thanks
Two things come to mind (1) there is a short in the charger or (2) the light is simply out.
Oct 23, 2013 | Ryobi Multi-Volt Battery Charger
No light comes on my charger when i plug in my new p103 battery into charger no 1423701?
does the outlet work that the charger is plugged into... is the battery completely dead and the charger can't see it... is the charger even plugged in... or is it even any good ???
Will a ryobi 18 volt charger replace a coleman powermate battery charger?What's your problem?
They look different in their shape where the battery goes so I would say no. To be safe always use the charger from the same manufacturer. There are a few different types of batteries too so it is always best to use the model number of your original charger to search for the replacement.
Aug 08, 2012 | Coleman Cable Coleman 18 Volt Combo Drill...
Will 14.4 volt charger charge 18 volt battery ryobi
I'm afraid not. It will damage the battery if you try. You'll need to get the correct charger.
Jan 12, 2011 | Ryobi Multi-Volt Battery Charger
I have a ryobi charger 1423701. but it does not charge at all
If it's not charging and your batteries are still good then more than likely the unit is shot. You can try cleaning the contacts on the unit and your batteries and see if that helps.If you know someone with a universal charger try your batteries on that to make sure it's not them that's the problem. Check ebay for a used one at a cheap price. This is not a fix you can do unless your a techie and it's not worth sending off to Ryobi for a factory fix. i just replaced my panasonic charger for the same reason, but i had it for 10 years.
Oct 14, 2009 | Ryobi Multi-Volt Battery Charger
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a Ryobi 18v battery charger model #1423701.....
Oct 06, 2009 | Ryobi Multi-Volt Battery Charger
Hi, I have a Ryoby charger number 1423701 but I
your batteries have possibly developed a memory and are probably shot or it may be the charger local toolstore should be able to test them both.Which ever one is bad it will cost more to buy a charger and battery than it will to buy a new drill .whatever you do ask the shop people how to stop the battery from developing a memory or if you want to come back to me when you have them fixed up I will be happy to tell you.please let us know how you get on ,thankyou
Aug 10, 2009 | Ryobi Multi-Volt Battery Charger
Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
Mar 16, 2009 | Ryobi Drills
Good Luck
Mar 07, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi Multi-Volt Battery Charger Logo
83 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
roeb
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
