Question about Cell Phones
How do i put it in pairing mode. lost my instructions and changing phones.
    Sergeant:
  • 240 Answers
The phone does not go into pairing mode the device you are connecting does ( ie Bluetooth headset ) you use the phone to search for the device
Posted on Aug 04, 2010
Hi I have an emerson em227 bluetooth and haver lost the direction. I need the instruction to start the paring process
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on your phone' screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds).
By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards, Carlos
Jan 13, 2011 | Emerson EM227 Bluetooth Headset
Tip
How to Pair or Connect the Plantronics 510 Bluetooth Headset to your Bluetooth...
1. Turn on Bluetooth within your phone - Consult phone instruction booklet
2. Put phone into pairing mode - Consult phone instruction booklet
3. Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
4. Select "Add new device" on your phone.
5. Select the Plantronics headset when prompted. Enter "0000" as passcode.
6. Your 510 headset will now have a continuous blue light blinking.
7. Choose "Yes" if your phones asks if you want to bond to the 510 bluetooth headset.
8. Your phone is now paired with the Plantronics 510 headset and ready for use.
on Jul 14, 2010 | Cell Phones
Lost instruction manuil for my mad catz bluetooth wireless headset
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device, then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
Sep 04, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
I am trying to pair Visor Blade,Supertooth-Lite with mobile phone
Try holding down the green button release the mike then enter 0000 the phone should then pair. This worked for me so I hope it will work for you.
Mar 16, 2009 | Cell Phones
Pairing a nexus drivesmart
To put the Drivespeech into pairing mode - with power OFF, press the power on button until the Drivespeech powers on and CONTINUE to hold the button until it announces it is in pairing mode and the LED flashes alternate Red/Blue.
Select 'Discover' on your phones Bluetooth menu and enter the code when requested (usually 0000 or 1234)
HTH
Jan 29, 2009 | Cell Phones
I have a LG scoope that I'm trying to hook my motorola H350 up to it. I lost the instructions and I don't really know if it will go with it. I need help!!!!!!
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
Jan 12, 2009 | Motorola Mobility H300 Wireless Headset
Need to setup H300 bluetooth to my LG VU phone! How do I do this?
Jan 08, 2009 | Motorola Mobility H300 Wireless Headset
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Pairing a samsung wep200 headset to a samsung blackjack
blue tooth is a usb transmitter. so obvisously u got to get the 2 to the right frequency. look for a small button to press on the samsung...sounds like u need the manually. look online for it. good luck. Crazylarry
Jun 27, 2007 | Eforcity Samsung Bluetooth Headset WEP200...
Cell Phones Logo
88 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
