Question about Moen & One Handle Tub & Shower Faucet
Moen 82910 brb is not getting hot enough - Moen & One Handle Tub & Shower Faucet
2 Suggested Answers
snap101
  • 117 Answers
SOURCE: Temp control doesn't allow water to get hot enough
remove the handle and there should be a white plastic deal behind the handle that you can remove it's a temperature limit setter so people dont burn themselves remove it and you will get the full hot water
Posted on Aug 10, 2009
How do I adjust my exacttemp shower valve?
Where it suddenly became not hot enough, it's probably not an adjustment. It sounds like the stem needs to be replaced
Feb 28, 2014 | Moen Home
Moen Eva two handle lavatory faucet - hot water leak from faucet. Old cartridge removed (had to get a special tool to remove it), new cartridge installed, and leak fixed. Four days later, leak is back...
Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
Jun 08, 2011 | Moen T943/MO4999 Eva Deck Mount Whirlpool...
Moen shower valve turns on full to cold water but flow becomes minimal when valve is turned to warm/hot. not getting enough warm water to shower. can this be fixed without rplacing the valve?
yes and no. Find hot water heater and insure cold water supply valve is open all the way. check to see if there is a hot water supply value and that its open all the way. If you replace shower value over iron pipe on the hot side it is corroded up replace pipe and value. If copper, find hot side, find value and open it up.
Nov 28, 2010 | Moen & One Handle Tub & Shower Faucet
Can you adjust hot to cold ratio on moen single handle shower faucet
Pull off the handle and there are limiters located under it. They come set with not enough hot allowed, I have found. It is an anti scalding issue.
Sep 29, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen kitchen valve is too cold in hot position & not hot enough in any position. I have changed all the seals & my hot water supply is hot. I have not replaced the whole cartridge.
My husband is a plumber. he says u have the cartridge in on the wrong side- meaning u have to spin it 180 degrees. hope this helps! if that doesn't work then replace the cartridge.
Jan 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Aug 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen & One Handle Tub & Shower Faucet  Logo
148 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
