Question about Air Tools & Compressors
Question is whether to get an Kobalt 80 gallon 14 CFM at 90 one stage or a 60 gallon IR 18CFM at 90 if the price is the same and CFM is not the issue, but the quality of the item?
    Champion:
  • 205 Answers
Your choice of an air compressor should be based on what you are going to be using it for first of all .single stage compressors are good for about 125 psi 2 stage up to 175.which whatever one you choose do not get a oilless they wont last .you want a cast iron pump which requires oil lubrication.pumps which are made of aluminum are throw a ways
Posted on Aug 13, 2010
What the torque settling on a 1.8spi vauxhall cavalier 1994
Cylinder head Renew bolts: Yes Tighten: 25 Nm Tighten: 90° Tighten: 90° Tighten: 90° Other engine tightening torques Main bearings Renew bolts/nuts: Yes Main bearings Stage 1: 50 Nm Main bearings Stage 2: 45°-60° Big end bearings Renew bolts/nuts: Yes Big end bearings Stage 1: 35 Nm Big end bearings Stage 2: 45°-60° Oil pump to cylinder block : 6 Nm Sump bolts : 15 Nm Sump drain bolt : 55 Nm Flywheel/driveplate :
  • Use new bolts and tighten as follows:
      • 1,4/1,6 = 35 Nm + 30° + 15°
      • 1,8/2,0 = 65 Nm + 30° + 15°
  • "Pot"-type flywheel = 65 Nm + 30° + 15°
  • Tighten drive plate to 60 Nm.
Clutch pressure plate : 15 Nm Crankshaft pulley/damper centre bolt : Use new bolts. Tighten centre bolt to 130 Nm + 40°-50°
Camshaft sprocket/gear : 45 Nm Camshaft/rocker cover : 8 Nm Inlet manifold to cylinder head : 22 Nm Exhaust manifold to cylinder head : 22 Nm Spark plugs : 25 Nm Lambda sensor (Oxygen) : 30 Nm Chassis tightening torques Front hub :
  • Tighten nut in three stages:
    1. 130 Nm
    2. Slacken off
    3. 20 Nm + 80°-90°.
Steering track rod end : New nuts 60 Nm Brake disc to hub Front: 4 Nm Brake caliper to carrier Front: 30 Nm Brake caliper/carrier to hub Front: 95 Nm Brake caliper/carrier to hub Rear: 80 Nm New bolts ABS sensor Front: 8 Nm ABS sensor Rear: 15 Nm Road wheels : 110 Nm
There you go pretty much covers everything hope that helps
Jan 11, 2015 | Vauxhall Cars & Trucks
Ingersol rand 80 gal 5 hp manual
follow the link
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-877.pdf
Sep 07, 2014 | Ingersoll Rand SS5L5 Ir Electric...
My kobalt 80 gallon air compressor won't turn on
BE CAREFUL! Jump the pressure switch and see if it starts. If so, replace the switch. If it doesn't start but hums, cut the power and try to turn the compressor by hand. Free it up if possible. If it does not hum, look for a reset on the motor or a blown fuse or breaker.
Dec 14, 2013 | Kobalt 5.2 HP 80-Gallon 175 PSI Electric...
Cylinder head torque specs for opel corsa 8valve 1.4l 2005 model
Corsa 1.4I Engine code Z14XE 2000-2004
Bolts must be renewed
stage 1. 25Nm
stage 2, + 90 degrees
stage 3. + 90 degrees
stage 4. +90 degrees
stage 5. + 45 degrees
Sequence
10 6 2 3 7
9 5 1 4 8
bolts 7 & 8 are nearest to the flywheel side of the engine
Engine code C14NZ 1993-1998
Stage 1. 25Nm
stage 2. + 60 degrees
stage 3. +60 degrees
stage 4. + 60 degrees
Sequence as above.
stage 1. 25Nm
Sequence
10 6 2 3 7
9 5 1 4 8
Stage 1. 25Nm
Sequence as above. <br />Corsa 1.4I Engine code Z14XE <b>2000-2004</b><br />Bolts must be renewed<br />stage 1. 25Nm<br />stage 2, + 90 degrees<br />stage 3. + 90 degrees<br />stage 4. +90 degrees<br />stage 5. + 45 degrees<br />Sequence<br />10 6 2 3 7<br />9 5 1 4 8<br />bolts 7 & 8 are nearest to the flywheel side of the engine<br />Engine code C14NZ <b>1993-1998</b><br />Stage 1. 25Nm<br />stage 2. + 60 degrees<br />stage 3. +60 degrees<br />stage 4. + 60 degrees<br />Sequence as above.
Jan 09, 2013 | Opel Corsa Cars & Trucks
Which type of a compressor machine has a better to a plant consuming 500 CFM of air at an average of 120 psig screw type or piston type
A screw type compressor will be the better solution. Screw compressors are made to run. You can also get screw compressors with variable speed with means electrical savings. Ingersoll has screws that are up to 150 psi. Atlas Copco has screws that I know go up to 175 psi. I don't know if it's still available but the Government had assistance plans or grants if purchasing a compressor with a power savings feature.
Jun 22, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Need to know type of oil it takes
I recommend type 30 all season full synthetic. It can be purchased on line, at an IR distributor and most Graingers.
Apr 14, 2010 | Ingersoll Rand SS5L5 Ir Electric...
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
146 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
